I downloaded it, decompressed it, and then when i go to open the app, nothing happens. when i look at the dock, the little arrow that indicates that its opening flashes for less than a second and goes away...i dont know whats wrong. can someone help me out? thanks!
--sprout
Wow, i have not heard of this one...
what OS are you in. I think it takes 10.2 but the latest version says restores 10.1 compatibility....
its such a small simple app what could go wrong....
have you restarted in a while?
do you have too many apps open your running low on memory...
just shooting out some theories here... -
i just figured out the problem... for some extremely stupid reason, anything i decompressed using the new stuffit didnt work! so i deleted everything, reinstalled stuffit 7, and it worked. pretty wierd eh? thanx for trying anyway
that could be the cause, yes.
if its not unstuffed properly, the app isnt "written" to your HD in proper format, so its not going to work.
glad you sorted it out.
check out my webpage, in my signature, for a nice "how to" if you get lost along the way
ProRes 422 (LT) 4.29GB wont open
By RenderFi in forum MacReplies: 8Last Post: 11th Dec 2010, 10:54 -
Downloaded movie wont open..
By bahnan in forum Newbie / General discussionsReplies: 7Last Post: 20th Jun 2009, 11:56 -
Help the prgramme wont open!!
By amber123 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 23rd Apr 2009, 07:51 -
Sony vegas pro 8.0 wont open my files.
By Blake_t in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2008, 11:44 -
.mov wont open in quicktime
By lonewolfsas2k4 in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2007, 12:25
