I have lots of home movie (MiniDV) where I used a handheld mic. The mic is mono, so the sound only comes out of one speaker.
What is the best way to mix the sound during the editing process so that I get (fake) stereo sound? So I need to extract the sound from the AVI file, play with the WAV in an audio program, and then stick it back to the AVI file? Again, what software can I do this with.
sound forge has a mono to stereo setting with invert phase psuedo - stereo setting or just mono to stereo
just throw your DV avi into that and re-render audio (select avi/DV) (it will render to another dv avi without touching your video)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You should be able to do this right in your video editing program (unless it's too crippled). I use Vegas 4 to edit and burn caps of old home videos that have mono sound. When I render the video I specify stereo for the audio and it just puts the mono on each track.
Or, for a quicker solution when recording in the future, buy one of these for $1.99 (should be available from Radio Shack) or use this website: http://www.audiogear.com/AudioAdaptersMini.html
Then you'll have the same audio going to both channels when you record, and you don't have to futz around with any programs later.
Ethernet (n): something used to catch the etherbunny
Where Can I Buy a mono-stereo 3.5 mm mono to stereo L-adapter?
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Nov 2009, 05:45 -
VHS Mono to Stereo
By Yaemish in forum AudioReplies: 2Last Post: 22nd Dec 2008, 10:42 -
mono to stereo?
By wingfan in forum AudioReplies: 5Last Post: 22nd Nov 2008, 12:44 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
mono and stereo?
By sharmine in forum Newbie / General discussionsReplies: 9Last Post: 12th Apr 2008, 21:24
