On the audio file from DVD2AVI there may be in the long audio file name a statement that says -Xms (like -107ms, that mean -107 milliseconds). When encoding the file in TMPGENC Wizard there is the option for Filters, select Source Range, down at bottom middle there is "Audio Gap Correct". But the -107ms needs to be entered as 107 (if the number was +107ms in the file name, you would need to enter the number as -107) That will correct the sound file to be + or - Xms to sync up with the file.
Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 18:24 -
Tmpgenc 3 audio video out of sync before encode
By marioval in forum Authoring (DVD)Replies: 8Last Post: 30th Jan 2008, 15:07 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 15:10
