Could n e 1 please give me some advice, posted a message about this last week, aint heard n e thing yet. All i would like to know is to use Spruce Up DVD, when i want to import an M2v file, do i need n e codecs please ???? I have been using programme successfully until i had to format pc, now i have set it up again, i can't get Spruce to recognise the M2v file, once i have split sound/vid with Vob Edit, can somebody please give me some advice ???
Max
hi there m8,
shouldnt needs codecs no, i always had spruce up happy with an m2v. I would suggest reinstall spruce or see if vob edit is outputting the m2v file extension, but it is not truly just m2v i.e it is not the right format. I have hhad spruce up reject files before, re-split them and then they worked - weird !
cheers
bob
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
Hack needed
By chisholmh1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Dec 2007, 11:32 -
Spruce Encoders
By zerohash in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 06:10 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 02:59 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
