I finally set my system up with my slower, smaller capacity drive as the system drive and my larger, much faster harddrive as a storage drive.
Question is, when I install capturing or editting programs, which drive do I install them on?
If I put them on the system drive and merely save the outputted/captured file on the faster drive, is it not taking advantage of the hardware setup (which I've heard to be better than if the faster drive was the system and storage drive for video stuff)?
Or do if I install them on the video drive, will this be defeating the purpose? From what I've read and heard from others, the stuff programs and Windows run in the background impedes the editting and capturing process.
Any help would be greatly appreciated! Thanks
Results 1 to 11 of 11
I'm far from an expert, but I think you'd be better to use the larger-faster drive for the captured files and put the programs on your system drive.
For most programs I think the vast majority of the program is in memory (unless you don't have much memory), so I don't think putting the program on a faster hard drive will speed the program up much except when first loading the program.
If you're capturing to the same hard drive that is using programs then you'll be more likely to drop frames because the hard drive has to constantly jump back and forth on the drive between storing the captured video and accessing any other data that it needs from that hard drive.
True- Windows is constantly accessing data for programs running in the background and it can't store your video capture while it's doing that. That's why it's better to store the captured video to a separate HD. -
and it does hurt performance if that separate drive for capturing is a primary slave as opposed to master, right?
No. I've used slave for capture too.Originally Posted by jorwex
My primary system is as follows:
IDE0 Master - C: System 60GB/7200 (also has G: partition for documents)
IDE0 Slave - D: Encoded video files (used to use as capture drive) 100GB/7200
IDE1 Master - DVD-RW 4x
IDE1 Slave - CD-R 16x
IDE2 Master - E: Capture 200GB/7200
IDE2 Slave - DVD-ROM 16x
IDE3 Master - F: DVD projects 160GB/7200
IDE3 Slave - unused
My secondary system is as follows:
IDE0 Master - C: System 40GB/7200
IDE0 Slave - DVD-ROM 16x
IDE1 Master - DVD-RW 2x
IDE1 Slave - D: Capture/Video 80GB/7200
Slave versus master only matter on the same channel (and that's only for file copying and source->target burning). This has no effect on capturing. Capturing doesn't use both drives. The capture program loads into RAM for the most part. The SWAP usage, if any, would be negligible.
Keep the capture programs on you system drive.Want my help? Ask here! (not via PM!)
smurf
I don't understand this combo:
7200RPM IDE drives are ATA66 compliant, where that DVD-ROM drive is probably not. It might not even be ATA33 compliant. It's it not 66 compliant... how is it not effecting the speed of that 200G?
Drive speed tests I've run have all showed lower performance when connecting a non-ATA66 compliant drive (of any type) to a compliant drive on the same cable. Even having the CD/DVD drives are enabled for autodetect in the BIOS can/will slow down a controller <by my experience>.
Just wondering... -
Zero effect.
That is running off a Promise UDMA 133 controller.Want my help? Ask here! (not via PM!)
* The TX2 has two ATA ports, which offer separate device timings that permit the use of different speed drives and/or devices to the same channel without adversely affecting the device speed. Each device will run at their highest-rated speed regardless. *
COOL!!!!!!!!!!!!!!!! -
On most drive controllers, you can see huge performance losses whenever too non-identical drives are paired. It is not real common, and for the most part any two roughly similar drives on the same channel will be OK, BUT if you experience any frame-drop issues, try testing the capture drive alone on its channel.
The capture progs should definitely be on a different drive, and ideally a different channel, from the capture drive. -
Not with Smurf's controller.
READ THIS: http://www.littlewhitedog.com/reviews_hardware_00034.asp -
It's about 1/3rd down the page:Originally Posted by bottle-necked
"The TX2 has two ATA ports, which offer separate device timings that permit the use of different speed drives and/or devices to the same channel without adversely affecting the device speed. Each device will run at their highest-rated speed regardless. "Want my help? Ask here! (not via PM!)
FWIW if you only use the capture drive to capture...
Then when done with the current project you can format it and be back to a blank and defragmented drive very quickly.
Cheers
Video capture straight to temporary storage?
By travail in forum Capturing and VCRReplies: 6Last Post: 2nd Jul 2011, 20:20 -
Suggestions for VHS to Hard Drive Capture and Storage
By hobbster in forum Capturing and VCRReplies: 6Last Post: 27th May 2011, 15:20 -
Video Archiving using Mp4 - MKV on a Western Digital storage drive
By ejai in forum DVD RippingReplies: 23Last Post: 9th Sep 2009, 23:50 -
CD storage on hard drive player.
By hiliftjack in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2009, 13:26 -
How to install INTEL MATRIX STORAGE MANAGER DRIVER
By Tbag in forum ComputerReplies: 1Last Post: 7th Jul 2007, 16:05
