The reason I ask is that I have been using both, on demo, and I feel that I completely understand DVDLab, but havn't mastered DVD Architect yet,,,
Looking for people who have experience with either and what there overall thoughts are......![]()
Results 1 to 12 of 12
Better for what? It really depends on what you want to do? I know that DVD Lab doesn't support subtitles, multiple audio streams, or multle VTS. I don't know if Sonic's program does, or if you want/care about these features.
Bottomline is only you can answer that question. -
Originally Posted by LabanB- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Originally Posted by Vejita-sama
Originally Posted by mtrichardson
I choose DVD Lab, personally. I find it gives me a lot of bang for the buck, and I'm totally comfortable with it's interface, workflow and process.
I haven't worked much with DVD Architect, but it seems capable.
I would highly suggest you download trial versions of both and work with them, see which you like better and which is a better fit. One will feel "better" than the other.- housepig
Housepig Records
out now:
DVDLab gives you much more flexibility in making your menus, selecting your buttons and frames. It gives you much more control over the the navigation buttons. Making motion background is easy. Making motion buttons takes more doing. You'd have to make a motion button clip in another sw, because DVDLab can not render mpeg. Drawbacks to DVDLab are being fussy about all audio be the same. Also totally lacks any previewing capability. You can only preview navigation with a remote controller. You have to compile your the DVD and then you can watch it on a player sw. You can't preview it in DVDLab. This is big drawback in my opinion. If you don't like how the DVD works, you have to make the changes and compile again and then watch, and so forth.
InDVDArchitect I could not find much flexibility in making menus. It's more a cookie cutter approch. They have a few menu themes and not many frames or buttons. However, making motion buttons is far easier than DVDLab. You can preview it right there with motion background, and motion buttons all working in preview. It has a very large preview window. Very cool. DVD Architect really shines in it's previewing capability. -
Originally Posted by falberni
No, DVD Lab does not accept multple VTS, multipe audo streams or subtitles. Yes I can work around that but I can not generate a menu to select a different audio or subtitle stream. Nor can I nativelly generate mulitple VTS.
I'm not saying DVD Lab is a bad program. But it's limited. If you don't mind hitting the buttons on the remote it's a good cheap way to author some very nice DVDs. If you want to author and have total control over everything it's limited. No insult, just a statement of fact -
I have both, and each has its own strengths and weaknesses. For example, DVDLab gives you much more precise control over menus and navigation, while DVD Architect provides a nearly unbeatable preview feature and allows combining 4:3 and 16:9 video and different bitrates for audio.
The biggest difference, though, is price. DVDLab is $99 (introductory pricing at $79) and is a stand-alone product, while DVD Architect must be purchased with the Vegas 4.0 editor, a combination that costs $800 (less for upgrade pricing and such). That alone would probably dictate your decision.Don't sweat the petty things, just pet the sweaty things. -
The multiple VTS will come provbably soon to DVD-lab also multiple audio will be quite soon. I guess the subtitles will come qfter that.
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 12:28 -
DVD Architect 5.0
By Mr. Robinson in forum Authoring (DVD)Replies: 1Last Post: 4th Nov 2009, 10:59 -
DVD architect
By romanstopme in forum Newbie / General discussionsReplies: 4Last Post: 7th Apr 2008, 00:57 -
DVD Architect help
By monks19 in forum Authoring (DVD)Replies: 11Last Post: 23rd Aug 2007, 06:46 -
DVD architect
By Abiyad in forum EditingReplies: 1Last Post: 19th May 2007, 08:02
