I just purchased a KWorld V-Stream DV/AV Expert card (it uses the Conexant CX23883 chipset) to capture my Hi-8 videos to MPEG in realtime. I plan to burn these old videos to DVD with a little bit of editing.
I had been using the Pinnacle Studio AV (DC10) card with no problems except that it only captures in motion jpeg and the capture files were huge and rendering takes forever.
When I plugged my camcorder into the new VStream card (S-Video), I noticed a horizontal line at the very bottom of the preview screen. Below that line were one or two scan lines from the top of the image. In another words, it looks like the horizontal sync is slightly off. The same lines appear in the captured video as well.
I tried uninstalling and re-installing the drivers, moving the card to a different PCI slot and using different capture software but the lines remain.
Any ideas what is going on or how to fix it? Do you think the lines will appear on a TV playing the DVD (i.e. will overscan make the problem irrelevant)?
Thanks in advance from a newbee.
It should play fine on your TV. TV video is overscanned. About 5-8% of the picture is cut off by the TV. For analog sources you'll often find these lines at the bottom of captures, they do not show up when played back on the TV.
If you clip it, then play it back on your TV it will just overscan that image and you'll lose even more picture. Unless you plan to only play back the video on your PC (Divx/xvid) just leave it alone.
Vejita-sama
Thank you. You were correct. With the overscan, I cannot see the artifact at all.
Unfortunately, however, the quality of the image sucks compared to the quality of the image I captured with the DC10 card.
I've posted a new topic covering that. Hopefully, I figure out a way to improve the image quality.
Single Horizontal Line in Video
By PhilP3 in forum Software PlayingReplies: 5Last Post: 8th Dec 2011, 15:08 -
Diamond VStream any feedback?
By halekon in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Jul 2011, 13:35 -
Black horizontal lines when capturing
By cyanure in forum Capturing and VCRReplies: 3Last Post: 14th Aug 2010, 09:09 -
Weird horizontal line on top of the black area when playing movies(screen).
By Nitrius in forum Software PlayingReplies: 2Last Post: 23rd Aug 2008, 14:12 -
Horizontal Line near bottom of video
By tdelarosa in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2007, 15:09
