Results 1 to 9 of 9
  1. Lets say I have some info on a cd and the only way to extract the data on your computer is by a password... is this possible
    or
    Is winzip or winrar the only other way.
  2. Member pyrate83's Avatar
    Alive on XBOX LIVE!!!!!!!
    Why don't you give us more information, like what kind of "info" are we talking about here???
  3. I think that winzip can create a password protected self extracting exe file. I have never done it though.
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  4. Why don't you give us more information, like what kind of "info" are we talking about here???
    Just data.
  5. Member pyrate83's Avatar
    I believe solarjetman may be right...although I have never done it either.
  6. Password protected Zip files don't offer the best protection.
    See Here
  7. google for PGP .
    The electronic components of the power part adopted a lot of Rubycons.
  8. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    If its only a slight concern winzip with a password. If it REALLY needs to be secure. PGP all the way. http://www.pgpi.org/products/pgp/versions/freeware/
  9. Originally Posted by testicool
    or
    This program
    or
    another program
    Originally Posted by jagabo
