Now that the hacked firmware for the Pioneer 106D is released, Im looking for the good cheap 1x media to burn at 2x. Any suggestions?
Here is the link for the firmware for those who have one. Thanks NIL.
http://pioneerdvd.rpc1.org/DVR-106D%20v1.07%20-%20RPC-1%20+%202xDVD-R%20+%2012xRip.zip
The CompUSA 10 disc packs (supposed to be Lead Data discs, haven't really checked mine but assume so) seem to be good. Only one failure and that was from a power failure. And I'm verifying almost all, so they are checking out ok. Good for local if you have one near you.
Alan -
Ritek GO3 1x.
Burns at 2x with my NEC ND1300A (origonal firmware 1.05). Got 50pack for $0.92 each disc at SuperMediastore.com -
Is there any place that sells the Ritek G03 discs in single pack jewel cases? I'd like to test them in my nec 1300A AND dvd player before buying a bunch. Thanks.
I was under the impression that the 4x DVD-R RITEK discs (G04) were better than the 1x/2x DVD-R RITEK discs (G03).
No I don't mean just speed but more in terms of quality of manufacting including less problems such as edge burn playback problems, fewer bad discs in a batch, etc.
Anyway care to comment?
ive had good luck with ritek g03, go4, lead datas, and even princo.....
decent luck with optodisks, and bad luck with samsung and beALL's ... they could have been a bad batch, but i wont try them again -
I've burned about 30 optodisc at 2x so far of the 40 I picked up under Compusas name brand, so far of those 30 only one disc burned badly and I could tell as I burned that something was wrong from the sounds the drive was making. So Optodisc are ok, but Ritek is still my #1 pick for 1x disc to burn at 2x.
Ritek G04 are good with the little time I spent with them, but 4x disc are a little off topic to this thread.
New PC Burns With Errors
By NOIC in forum DVD RippingReplies: 22Last Post: 29th May 2009, 13:12 -
burns fails. help
By dymx in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2008, 14:54 -
CDROM that burns commercial media
By Krispy Kritter in forum MediaReplies: 6Last Post: 19th Dec 2007, 10:30 -
Bad burns
By jalfirov in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2007, 14:14 -
Bad Burns
By jalfirov in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2007, 04:23
