    Feb 2003
    Germany
    hi!
    is there a plugin or something for tmpgenc so it can open and convert realmedia videofiles? or do i have to use a different programm for it? is there any which can also batch converting?
    thanks
    bender
    Aug 2003
    Des Moines, Iowa USA
    AFAIK, tmpgenc can not convert real media files. Some one correct me if I'm wrong. Try using EOVideo or TINRA.
    Open WIDE for Chunky!!!
    Feb 2003
    Germany
    found the solution by myself!
    i've installed RealMedia Alternative and now tmpgenc is able to read rm files!
    the only thing is, i sometimes got problems with the sound!
    cu
    bender
  4. If you're having trouble with the audio why not try using EO-Video to convert the audio from the RM file to WAV and then use TMPGENC to put the original video and the converted WAV together?
    What is "Real Media ALternative" and where did you get it from?
    I'm currently using EO-Video to convert RM files, but the Video quality isn't as good as TMPGEnc, plus you can't add any filters (cropping, etc) ;o(
    Thanks,
    NiVZ
  5. Member Devanshu's Avatar
    May 2003
    I agree...EO video is the best way to convert rm files. Sefy has a great guide on how to do it and it's farily easy.
