THe best thing about this is no copy protection........![]()
But only VCD quality![]()
Results 1 to 17 of 17
yeh I still have mines... i ocasionally use it for vhs back up. I wish i used it more though but when i got my sony dvd burner, I kind of side line my terapin... I definitely will always keep it though... i also use it for home movies... people in my fraternity love to be able to down load videos of them acting crazy drunk!
i'm looking for one, are they even still for sale?? or just on ebay?
You win some, and you lose some, and some get rained out... -
ryanreko,
Last time I was at Micro Center, in Richardson, Texas; a few weeks ago.. .they had STACKS of the Terripin VCD Recorders for sale..but they were selling for 299 dollars.
So, I looked at the Micro Center Online website, yep, you can order 'em there...here's the link =
http://www.microcenter.com/search_results_e.phtml?dropdown_method=keyword&dropdown_key...=22&submit.y=6
I do have a few problems with the Terapin VCD recorder.. yeah..it's good for what it does..records anything from any source..BUT...it only records in Mpeg 1 format, the ordinary 1150 bitrate...and. as we all know; simple VCD's can't handle action sequences at all well..
I've asked the people who manufacture the Terapin VCD recorder (thier nationwide distributer is located right here in North Texas).. they have NO PLANS to upgrade it so that it will also record in Mpeg 2 format..there is no way to apply firmware that will upgrade it.
But my major problem with the Terapin VCD recorder is that it applies it's own PROPRIATARY Headers to the vcd. In other words, ya CANNOT copy a vcd that's been made with a Terapin VCD recorder..
I have had to RE-Encode all of the VCD's that I've made with the Terapin VCD Recorder with TmpgEnc..just to get a different HEADER that will allow TmpgEnc, and VCDEasy and TmpgEnc DVD Author to RECOGNISE the video mpeg files.
One GOOD thing that the Terapin does is that it records videos in 320 x 480 resolution...which is DVD compatible resolution... :>) so ya CAN make DVD's outta the videos made with the Terapin VCD Recorder.. ya just gotta RE-Encode 'em first to get a proper HEADER that can be RECOGNISED by Tmpeg DVD Author.. or VCDEasy. -
My local Sam's Club has them on the shelves for $199. I would probably buy one if they were $99.
......with the new recorders coming out in the future....you might get your wish 8) For $100 I might have some fun wid it.
Do the terapin's have a tuner and timer? If they have a timer how many events can they record? Thanks for any information?
jim15800
Nope..Terapins don't have a timer, and yes, it can record on an ordinary cd up to probably 78 minutes..BUT..you can stop recording..then resume recording on the same cd later..the Terapin goes into FINISH mode when you want it to..and closes the cd.
So, sure.. the Terapin can record multible events..but NOT with a timer.. ya gotta do it manually. -
The Terapin would be better if:
1. It had a cable tv tuner
2. It had timer programming
3. It had an XVCD mode of around 1500K Video, 128K audio -
Telemike,
I still have mine and have only used it a few times due to the quality it was below vhs quality.
I do not know if I got a bad machine or if I am expecting to much from this machine. I asked a few people on this and other forums to help me compare the quality of their machine vs my machine. However no one was willing to make a a few minutes of a dvd copy and send it to me.
There are other options that are rather in expensive a capture card or even a svcd recorder also found on ebay and usually have copy protection.
Just my 2 cents
VCD4ME
P.S. If anyone is willing to send me a few minute copy of a dvd so I can compare I would be estatic, so I could finally figure out my year old problem. I of course am willing to pay for your expenses.ThanksWe were all NEWBIES once and the only stupid question is the one that's not asked? -
Comparing the Terapin to doing a comparable VCD using TMPGenc, you can use filters and otehr tricks to make a better looking VCD.
Using a software encoder like Intervideo WINDVR and Cyberlink PowerVCR...the Terapin is way better than the Cyberlink and still better than WINDVR at VCD resolution.
Having looked at some VHS->terapin and DVD-> Terapin discs I have made they are watchable and not too bad. The best looking is DVD->Terapin with fast motion causing some blockiness and there is less sharpness compared to DVD. Overall it is comparable to VHS between the 6 hour and 2 hour mode.
I gave up on doing DVD copies with the Terapin when I discovered DVD2SVCD and making SVCD discs.
I will still use the Terapin if I want a TV movie or VHS transfer. -
this sounds like one of those vintage bits of kit that some people swear by, others swear at. I dont think anything like this was available in the uk, but I reckon even at $99 they sound like a waste. Was it shaped like a terapin? could it use 99min media?
Originally Posted by RabidDog
I had one for acouple of years, would only take standard 74min. cd-r/rw's.
sold mine right after picking up my panny dvd recorder, i feel if something is worth saving off tv, it's worth the quality of a dvd over a vcd any day& if i want it on a vcd, i'll just transfer it to my pc and burn it to a vcd
And as far as all the stuff i have read about copy protection on the panny standalone dvd recorder, i have yet to see italthough most of my transfers are from LD, some from tv/vhs, i have not had any problem with copy protection.
Its kind of like going to best buy and purchasing a vhs when the dvd is setting right next to it -
I have long since purchased a Sony DVD +/- writer, but I still use my Terapin on a regular basis. It's great for transferring less important VHS tapes when I want them on a disc of some kind with no hassle. Also, I have a portable Audiovox DVD player I watch on the road and the VCDs the Terapin produces are perfect for that (the Audiovox hates all manner of +R/-R anyway).
At the time I bought it I paid $250 and DVD recorders were over $600.
The only really good thing is that it is using an MPEG-1 Winbond encoder chip (the best mpeg-1 chip) and does a good job at VCD....
VCD just happens to be better than SLP VHS but not as good as SP VHS.
Does a good job at recording audio CD's too. -
I have the Malata SVCD/VCD revorder. I ordered a Terapin, but the production quality was so bad (the tray flap arrived broken) the store sent a Malata at no extra charge as a replacement because they had a slew of problems with them (they may be better now). The Malata quality is excellent for a capture device for both formats. I won't argue that someone who knows what they are doing using software couldn't get better quality, but not as quickly.
The only thing is that the VCDs get a slight lipsync problem. I can correct this using one of my cheaper DVD players that exhibits a slight sync problem in the opposite direction as the source, though. However, that eliminates any VCDs recorded from another source. The SVCD recordings are excellent though (at 37 and 40 minutes each). However, since I got a Panasonic DVD recorder, this has been collecting dust. I figure it would be good for a cheap "video letter" using my camcorder, but not much else for my needs.
A little more on topic, you would probably be better served getting a low-end Panasonic DVD recorder in the long run than getting one of these Terapins or Malatas (unless you really love VCDs).
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 19:23 -
Recorder help
By thermalguy1970 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 24th Apr 2009, 12:59 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
