I'm using version 1.5.1357 and I am coming across a bug with the dvd menu maker program.
The rest of the program operates perfectly but when I've finished creating a menu, the program builds the menu and then dvd menu maker will not terminate. I have to resort to Ctrl-Alt-Del to force the program to close as it has stopped responding. Once I have done this the main svcd2dvd window returns and operates as normal.
The final result is perfect and the generated menu works as it should. It's not a great hardship having to force the program to close, but it's just a bug I think you should know about.
OS-Win98 SE CPU-Athlon 2200XP 512MB RAM
Mr GuestGuest
WEll its good to know its working otherwise. That isn't the latest build and DVDMenumaker is at build 1.0.1360.32565. Maybe an update will solve this issue.
Let me know if not as I will look into it for you.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Mr GuestGuest
Thanks for the prompt response.
After I posted the previous message I noticed there was an update and I installed it. It still suffered from the same issue.
It's no hardship as the program still works otherwise.
Many thanks for a very useful piece of software. Keep up the good work.
Is my psu almost finished?
By WinSpecToR in forum ComputerReplies: 4Last Post: 10th Feb 2011, 00:08 -
PC locks up playing WMVs
By slipkid in forum Newbie / General discussionsReplies: 9Last Post: 12th Jun 2010, 11:04 -
Macrium locks computer
By pepegot1 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2009, 11:39 -
New XP Install locks up when opening videos
By ChezDigital in forum EditingReplies: 3Last Post: 27th Aug 2008, 06:59 -
Capture Locks on the first
By depsci in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2008, 14:21
