hi,
50% of all (S)KVCD's still give problems after
going through svcd2dvd: the sound is cracky
(voices are very high in tone(funny), but are in sync......and
theres a continious soft cracking sound in the background)
( http://kvcd.org/portal/ )
the strange thing is that dvdlab has no probs with them at all......
which forces me to use my 2nd best program....![]()
This KVCD is getting MORE and MORE popular every day!!!!
(120 mins High Quality SVCD on ONE CD!)........
I tried to put my finger on the reason, but havent gotten that far yet
why svcd2dvd has problems with most of them...........
I keep hoping after every update (keep em coming!) that the problem will be solved.........
handersGuest
Well I've never even seen a kvcd!
If someone wants to create a sample say 10MB+ and ftp it to me I'll see what the score is.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
handersGuest
sorry chrissy, i didnt mean it like that
well, i think kvcd is a real progress, similar to f.e. xvid for divx.....
well, anyways: i've put up a small (14MB) sample for you.
the quality of this one is not typical for SKVCD, but its average (can
be lots better->dont mind that 4 now....i dont know who made this one)
here's the link:
http://www.stramm.nl/kvcd-sample.zip
(ill remove it tomorrow)
Thx up ahead Chrissyboy for all your efforts! it was worth the few bucks
all the way!!! -
getting it now. I shall take a look to see what the issues are with this type. I'll keep you posted.
http://www2.svcd2dvd.com/samples/Kvcd.zip is the result of a default SVCD2DVD run on the mpg you gave me. Whilst i can't understand a word that being said in the sample it looks pretty good to me. Did you try it yourself to see if it exhibited the traits you referred to?
Code:Starting SVCD2DVD: v1.5.1362.29208 Begin time: 20:25:22 ******** Ripping SVCD images to get mpegs Analysing File: I:\Test_Area\Kvcd\kvcd_sample.mpg -->Processing 1 mpeg files. ############### New MPEG File ############### File: I:\Test_Area\Kvcd\kvcd_sample.mpg Horizontal Res: 352 Audio SampleRate: 44100 ******** Demultipexing original mpg file ******** Resampling audio from 44.1 KHz to 48 KHz ******** Multipexing elementry streams Analysing File: I:\Test_Area\Kvcd\kvcd_sample_DVD.mpg ******** Creating DVD... Creating VTS #1 ============ Complete ============ ============ Duration: 00:00:20.1406250
handersGuest
just my luck: the sample was no prob in your program......
as i said: some 50% doesnt make it correct: this
was one of the good 50%.......
ill try to find one that doesnt make it correct through svcd2dvd and post
a sample then ok?
thx for the work b.t.w.!
keep an eye on kvcd!
thx
Can my Laptop support TV Out?
By soneman in forum Software PlayingReplies: 12Last Post: 15th May 2008, 12:17 -
AVCHD support....please!
By motoxer913 in forum ffmpegX general discussionReplies: 2Last Post: 6th May 2008, 09:44 -
EyeTV Support?
By fromeout11 in forum ffmpegX general discussionReplies: 1Last Post: 7th Oct 2007, 10:37 -
Gamebridge support
By alsuse in forum LinuxReplies: 0Last Post: 17th Sep 2007, 22:12 -
SDK Support
By jain30 in forum Authoring (DVD)Replies: 3Last Post: 22nd Jun 2007, 08:50
