Hi y'all
I got Nero 6 and it's impossible to burn with it. It keeps on complaining that "drive is in use by another application" , but its NOT (I promise)![]()
What shall I do?
/Nisse
Try to run the neroclean.exe they provide if you upgraded from version 5.0.... it seems to have some bugs if you don't completely get rid of the old version first... "do it after you uninstall it".. which by now you have.. but I guess in your case what I mean is uninstall 6.0.. then run it to get rid of traces of 5.0.. then reboot and reinstall...
another thing the techs were telling me you can try first if you like.. is to remove all traces of cdroms period in device manager.. then let windows find your drive all over again. I've never had that problem but I had numerous techs argue with me that that what I should do If I do a firmware update of my plextor drive.... (I don't know if it will apply to you)..
and lastestly..... don't install the latest 6.0015 version of nero.... major bugs!!!!! too long to discuss now.. install the one before that.. or any one for that matter.... 6.0011 works well.
Let me know if you need help finding the older version of nero off their ftp site.. or the neroclean they provide..
Good luck..Don't do it, if you can't chew it!!!
AVIsynth refuses to work anymore... Plz help!
By Nagashi in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2010, 17:44 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
ADPCM Format ? WMP refuses to play
By drwho in forum AudioReplies: 2Last Post: 30th Oct 2008, 23:28 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
HTPC refuses to boot after current failure
By Jacobus Serpenti in forum ComputerReplies: 22Last Post: 19th Jul 2007, 03:41
