  1. hi, ive got an error on my TMPGEnc Plus which says 'Warning: Nothing To Output BFrame Decoder Lag' has anyone else had this?
    plz help
    moe
  2. 8) your input file is corrupt!
    The electronic components of the power part adopted a lot of Rubycons.
  3. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    Try to frameserve. And if you keep having this message (very rare), then you have to load your source to virtualdub so to fix it.
    In case virtualdub can open it direct, you have first to make it avi....
    Sep 2003
    Australia
    You can also get this message when the Xvid codec installed on your system is not compatible with the codec with which the file (movie) was encoded.
    Try installing either of these. Uninstall one before installing the other.
    http://www.roeder.goe.net/~koepi/xvid.shtml
    select the "latest (stable) binary"
    http://nic.dnsalias.com/XviD_Install.exe
