I want to have 140min of video on a 120min 4,7GB DVDR .
Is it possible ? Or should i cut it in two ??
What is your weapon of choice?
Standalone or PC based Burner?
For standalone there is proberly a LP function (decreases bitrate).
For PC based burner reencode at a lower bitrate.
Goto tools and find the bitrate calc.
For the record it is 4.38 'usuable' GB. 120 minute DVD WTF is that??
Ok, first off DVDR is a digital medium. It's not like analog. There is no min or max timelimit on a filesize limit. If you file is less than 4.3Gb you can put it on a single DVDR.
File size is controled by two (and only two) variables. Bitrate and source runtime. The size of your source, the resolution of your source, the resolution of the encoded MPEG, etc. Have ZERO effect on file size. Think about it:
3000kbit/s x 10 sec video = 30,000 kbit file
What the bitrate calculators do is tell you that for runtime X the max bitrate you can use to get a file that's 4.3GB (minus overhead) is.
Now, the lower the bitrate the lower the quality of your encode. The lower the resolution the lower the quality of your encode. With this in mind most people don't like to encode at full D1 (720x480) with bitrates belows 4000kbit/s, 1/2 D1 (352x480) at bitrates below 2000, or 352x240 at bitrates below 1000. But these are personal choices. You can get 10hrs+ on a DVD or as little as 60min depending on the bitrate you use.
So in answer to your question, yes you can get 130min of video on a single DVDR
16:9 .avi file doesnt fit the analog TV
By rekotc in forum Newbie / General discussionsReplies: 15Last Post: 1st May 2012, 13:01 -
1GB AVI to DVD doesn't fit on DVDR?
By juggaloninjachoo in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2012, 13:32 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
Avi Video That will Fit a CD
By niteghost in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 09:21 -
why won't my avi fit on a dvd-r
By bigwheels103 in forum Newbie / General discussionsReplies: 3Last Post: 24th Oct 2007, 21:08
