Hi,
I am trying to convert a SVCD to a DVD. Everything works fine so far, but I have a problem with the sound.
The sound on the SVCD is 44100 khz so I have to convert it to 48000 khz to get a proper DVD.
I have used DVD-lab to resample the sound and when I play the .mpa sound file then for example in Windows Media Player it sounds great. But when I authore a new DVD with this file (have tried IfoEdit and DVD-lab) the sound is horrible. Sounds somewhat like a very bad radio recording with lots of crackeling noises and some kind of echo.
I also have tried BeSweet and TMPGenc to resample the sound, with the same result.
Any help would be very much apricciated.
Thanks alot,
Alex
What I seem to be finding is if you are using MPEG as your only audio track, the volume level must not approach the maximum point. This does not seem to be a problem when playing on a PC, but on my standalone player the audio is very loud and distorted.
What I had to do is to normalize the volume level to -4dB of maximum (around 60%). Then it sounds fine on my TV.
(Sound Problem) Converting karaoke Vob file to mpg/ other video type cause.
By kiangtong in forum Video ConversionReplies: 1Last Post: 23rd Jan 2010, 03:45 -
Annoying popping sound after converting AVI to DVD
By Smudge249 in forum Video ConversionReplies: 2Last Post: 13th Oct 2009, 16:24 -
Converting WAV/MP3 to DVD-compatible sound file
By Erasmus in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2009, 21:41 -
Sound problem when converting AVI to DVD
By luvflt in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2009, 17:12 -
No sound when converting DVD (VIDEO_TS)
By jompa in forum ffmpegX general discussionReplies: 3Last Post: 18th Oct 2007, 16:48
