  1. I have two questions.
    I copy the VRO to the HDD then rename it to an mpeg file then
    Realoneplayer or WMP can play it , but why it's very lag (not lag played
    by PowerDVD ) ?
    Use Ulead Movie Factory 2 to convert this mpeg to VCD, it tell me " .MPG
    is not a VCD MPEG file.Please select a compliant VCD MPEG file".
    What's correct method convert VRO to VCD ?
  2. 8) what are the bitrate .. resolution ... audio sampling rate... of your vro file.. what machine makes it??
    The electronic components of the power part adopted a lot of Rubycons.
  3. Here's one way to convert VRO to VCD:
    1) You already have the VRO file imported in Movie Factory 2 so create DVD files and save to HDD
    2) Then use DVDx and open VIDEO_TS.IFO file from files you just saved, and convert to VCD compliant mpeg1 (DVDx guides are on this site.)
    Don't have answer to your first question.
