  1. Hi
    can anyone help me finding similar tool like dvd2svcd. wel not exactly similar but it should also out put files with quality, subtitles permanent or switchable, changing bitrate so it can be changed to 1 disk or 2 disk, and it shuld take less time ofcourse but time depends on speed of the pc after all.
    and the new software EAzy VCD, how is it.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    whats wrong with dvd2svcd ? it works well ..
  3. ok...
    DVD Decrypter
    DVD2AVI
    AVISynth
    Vobsub
    TMPGEnc
    VCDEasy
    Very high quality, only way to really speed it up would be to use a different encoder.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  4. Eazyvcd
    DVD2SVCD with CCE 1-pass VBR using D2SRoba plugin
