Hi all,
I'd like to have a bash at writing GUI's for a couple of commandline apps I use quite a lot.
I have a reasonable amount of experience in writing apps in Java, and I also have MS Visual Studio 6 - although I haven't had much experience with it.
Can anyone recommend:
1. Which language would be easiest to use (I'd like to use Java, but am not sure how well a Java app would be suited to the task). I'd be open to other suggestions, but preferably not anything where I'd have to pay for the IDE/complier etc..
2. Any resources/sites which might be useful - google's not been very helpful to me on this one.
Obviously if I have any success, the result will be freeware! (are there any licensing issues with this if I were to use VS6?)
cheers,
mcdruid.
Results 1 to 24 of 24
Using VS6 and the redistribution dlls are no problem.Normally all the necessary system dlls are in the Windows OS distribution under system32.
If your app needs other mcvc... or mfc dlls (in the restribution dir on the VS CD), you can give them away.JAVA is a little difficult in starting external processes.
The author of svcd2dvd uses .net development, but IMHO VS with MFC is the simplest way to go. -
Thanks mate - that's what I thought about Java - and it wouldn't really be taking advantage of the platform independance if I'm writing GUI's for Windoze commandline app's.
I'll have a look into VS6.
cheers,
mcdruid. -
If you decide to use VS6, then your choice would be mainly between C++ and VB.
Writing a GUI in C++ is hard. While in VB you would drag and drop and resize controls (like textboxes, buttons and checkboxes), in C++ you need to create classes, interfaces and stuff.
I'm not really into C++. I need to write some C code for a project and a friend created the dll "enclosure" and project and I'm adding relativelly plain C code in it. It's hard.
Other options would include Delphi. I got hands on Delphi 6, personal edition for free. The CD came with a magazine. I can upgrade to Professional edition or something for $99 but the personal edition is more than enough for writing small apps, like a GUI. And Delphi is very similar to VB in concept.The more I learn, the more I come to realize how little it is I know. -
Thanks SaSi,
yeah - I've done a little C, and I wasn't that keen! I've also had to write GUI's for Java app's from scratch without using a visual IDE, which again was not much fun.
It's sounding like VB might be worth a try - although if I could get hold of a free edition of Delphi, I'd be willing to have a look at that (whenever there's a viable alternative to M$...)
I'll let you all know how I'm getting on - it sounds like building the GUI (buttons/menus etc..) will not be too hard - but calling the external program might be more tricky!
Could anyone point me in the direction of a tutorial or something similar about how to do this? As I say, I've not had much luck with Google - maybe I'm searching with the wrong terms.
cheers,
mcdruid. -
Programming GUIs in VC++6 is an exercise in pain. So if you want to use VS6, you definately want to stick with visual basic.
Another option is to use something like wxwindows with perl or python. wxwindows is a cross-platform GUI framework, and perl/python are scripting languages. All opensource, completely free. -
I've written some GUIs ( VCDImager Tools GUI ) with VB5 (similar to VB6) and although some things are easier, there are other things which are a pain in the arse. One limitation (with VB5 at least -- don't know about VB6) is that I don't think you can pipe the output from a command console app.
This is irritating to say the least -- and I had to use all sorts of tricks to get the GUI for VCDImager Tools GUI to actually know what was happening with the state of the command console apps.
Regards.Michael Tam
w: Morsels of Evidence -
Visual Basic is to programming as Microsoft Frontpage is to HTML with its GI.
Virtualis
I'm fascinated with that. If it's not too lengthy
how do you execute a program and grab its output ?
All I've found so far is "shell" to execute.
I know there are strange VB extensions to directly access the API
but I don't know any of it.
all I need is a hint. -
All I can recomend is Borland C++Builder 6 very easy to throw an app togeather, but you still need to know 'under the bonet'
Only draw back (or plus?) is that the apps can be bigger because it tends not to relie on MS dll or comctls.
BTW I just wrote a GUI for ac3fix (not that it really needs one - but did see a request for it this morning)
Anyone want to try it
http://www.roderz.pwp.blueyonder.co.uk/euro2/
BTW should I be posting in the tools section? -
Roderz
I have an old video capture app lying around (VB code). I didn't write the original (based on MS vbvidcap) but made significant mods to it. I have 3 or 4 test versions and lost my best near final stuff somewhere but still have some of the early rough and dirty source code that someone can toy with. I am willing to post that and some other small sample vb apps from my win95 /win98 vb3,vb4 and vb5 stuff. I have vb6 and c++ but have not spent much time with it. There is lots of vb code all over the net but if the intent is to bring some of that discussion here then I'm all for that.
I've just noticed this new area so am just geting a feel for it right now. -
Originally Posted by FOO
What I did was (by scavagening code off the net) the following...
You can use VB to load/open a "console window". This is actually a function of VB rather than by using the shell command and loading "cmd". Then, in the console window, you can output text into it or run a program in it by using shell. The problem however, remains that the program that is executed by the shell command runs asyncronously with the VB program. However, since the program is running inside the VB console window, you can use a number of functions that grab text out of the console window.
What I did was for VB to basically loop and "look" at the text in the console window every now and then (every quarter second I believe) looking for specific strings. When it saw it, it would know that the console app had passed a certain stage.
To my knowledge (which is very limited in VB programming) I don't know any other way to pipe output to the VB app from a command console program (unlike Delphi or VC++). Unfortunately, this method is somewhat ugly as for it to work, VB needs to open a visible console window.
As to why VB doesn't understand all the standard Windows API calls, I don't know except to say that Microsoft is evil.
Regards.Michael Tam
Thank lots.
I might look into VC++ also as it allows more control.
VB is just so easy.
If they would just make the IDE for VC as easy as VB
I might get productiive.
I also have .NET and C# looks like it has interesting possibilities.
Even simple numbers are objects and have properties
and methods e.g. 1234.ToString()
Still doesn't help much with the Windows interface. -
IF you use MFC with VC++ and the Classwizard, developing a GUI is as easy as VB.The resource editor is very good at that.
Hi guys,
I didn't even know this FORUM existed :P
Nobody mentioned Delphi for GUI creations
I've made a few GUIs too. But, I'd also like to point out that you can do
just as much w/ DELPHI as you can w/ C++ and even if you have DLL's
that you need to comunicate or write front-end or shells, etc. w/ then DELPHI
will quite easily do it, and youcan build ALL your GUI's to glory high.
IMO, Delphi would be the easyiest to play w/ in these areas of GUI's. I know
that VB is another easy toy too, and I've use it for many years, but Delphi
all the way for me. Yes, VB can also use DLL's too. You just have to play
w/ it sometimes.. and..watch out for syntax like "Alias" when dealing w/
DLL's in VB. They can be tricky to work w/ when trying to cook up a sweet
dish (gui) or something..
VB example:
Private Declare Function apiGetUserName Lib "advapi32.dll" _
Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long
Delphi example:
Function BS_VERSION(var buf):buffer; stdcall; external '..\besweet.dll' index 2;
Anyways.. GUI development is fun stuff ta get into :P
-vhelp -
I don't see a clear way yet assuming the idea is to
take control ( fork/exec - spawn) of a console app and essentially
substitute yourself for stdio.
I'm an old Unix creature but I don't know how to exec a process and
open a pipe to it in windows. (or unix either probably)
I'm still reading. -
Creating a Child Process with Redirected Input and Output
The example in this topic demonstrates how to create a child process from a console process. It also demonstrates a technique for using anonymous pipes to redirect the child process's standard input and output handles. Note that named pipes can also be used to redirect process I/O.
The CreatePipe function uses the SECURITY_ATTRIBUTES structure to create inheritable handles to the read and write ends of two pipes. The read end of one pipe serves as standard input for the child process, and the write end of the other pipe is the standard output for the child process. These pipe handles are specified in the SetStdHandle function, which makes them the standard handles inherited by the child process. After the child process is created, SetStdHandle is used again to restore the original standard handles for the parent process.
The parent process uses the other ends of the pipes to write to the child process's input and read the child process's output. The handles to these ends of the pipe are also inheritable. However, the handle must not be inherited. Before creating the child process, the parent process must use DuplicateHandle to create a duplicate of the application-defined hChildStdinWr global variable that cannot be inherited. It then uses CloseHandle to close the inheritable handle. For more information, see Pipes.
The following is the parent process.
#include <stdio.h>
#include <windows.h>
#define BUFSIZE 4096
HANDLE hChildStdinRd, hChildStdinWr, hChildStdinWrDup,
hChildStdoutRd, hChildStdoutWr, hChildStdoutRdDup,
hInputFile, hSaveStdin, hSaveStdout;
BOOL CreateChildProcess(VOID);
VOID WriteToPipe(VOID);
VOID ReadFromPipe(VOID);
VOID ErrorExit(LPTSTR);
VOID ErrMsg(LPTSTR, BOOL);
DWORD main(int argc, char *argv[])
SECURITY_ATTRIBUTES saAttr;
BOOL fSuccess;
// Set the bInheritHandle flag so pipe handles are inherited.
saAttr.nLength = sizeof(SECURITY_ATTRIBUTES);
saAttr.bInheritHandle = TRUE;
saAttr.lpSecurityDescriptor = NULL;
// The steps for redirecting child process's STDOUT:
// 1. Save current STDOUT, to be restored later.
// 2. Create anonymous pipe to be STDOUT for child process.
// 3. Set STDOUT of the parent process to be write handle to
// the pipe, so it is inherited by the child process.
// 4. Create a noninheritable duplicate of the read handle and
// close the inheritable read handle.
// Save the handle to the current STDOUT.
hSaveStdout = GetStdHandle(STD_OUTPUT_HANDLE);
// Create a pipe for the child process's STDOUT.
if (! CreatePipe(&hChildStdoutRd, &hChildStdoutWr, &saAttr, 0))
ErrorExit("Stdout pipe creation failed\n");
// Set a write handle to the pipe to be STDOUT.
if (! SetStdHandle(STD_OUTPUT_HANDLE, hChildStdoutWr))
ErrorExit("Redirecting STDOUT failed");
// Create noninheritable read handle and close the inheritable read
// handle.
fSuccess = DuplicateHandle(GetCurrentProcess(), hChildStdoutRd,
GetCurrentProcess(), &hChildStdoutRdDup , 0,
FALSE,
DUPLICATE_SAME_ACCESS);
if( !fSuccess )
ErrorExit("DuplicateHandle failed");
CloseHandle(hChildStdoutRd);
// The steps for redirecting child process's STDIN:
// 1. Save current STDIN, to be restored later.
// 2. Create anonymous pipe to be STDIN for child process.
// 3. Set STDIN of the parent to be the read handle to the
// pipe, so it is inherited by the child process.
// 4. Create a noninheritable duplicate of the write handle,
// and close the inheritable write handle.
// Save the handle to the current STDIN.
hSaveStdin = GetStdHandle(STD_INPUT_HANDLE);
// Create a pipe for the child process's STDIN.
if (! CreatePipe(&hChildStdinRd, &hChildStdinWr, &saAttr, 0))
ErrorExit("Stdin pipe creation failed\n");
// Set a read handle to the pipe to be STDIN.
if (! SetStdHandle(STD_INPUT_HANDLE, hChildStdinRd))
ErrorExit("Redirecting Stdin failed");
// Duplicate the write handle to the pipe so it is not inherited.
fSuccess = DuplicateHandle(GetCurrentProcess(), hChildStdinWr,
GetCurrentProcess(), &hChildStdinWrDup, 0,
FALSE, // not inherited
if (! fSuccess)
CloseHandle(hChildStdinWr);
// Now create the child process.
fSuccess = CreateChildProcess();
if (! fSuccess)
ErrorExit("Create process failed");
// After process creation, restore the saved STDIN and STDOUT.
if (! SetStdHandle(STD_INPUT_HANDLE, hSaveStdin))
ErrorExit("Re-redirecting Stdin failed\n");
if (! SetStdHandle(STD_OUTPUT_HANDLE, hSaveStdout))
ErrorExit("Re-redirecting Stdout failed\n");
// Get a handle to the parent's input file.
if (argc > 1)
hInputFile = CreateFile(argv[1], GENERIC_READ, 0, NULL,
OPEN_EXISTING, FILE_ATTRIBUTE_READONLY, NULL);
else
hInputFile = hSaveStdin;
if (hInputFile == INVALID_HANDLE_VALUE)
ErrorExit("no input file\n");
// Write to pipe that is the standard input for a child process.
WriteToPipe();
// Read from pipe that is the standard output for child process.
ReadFromPipe();
return 0;
BOOL CreateChildProcess()
PROCESS_INFORMATION piProcInfo;
STARTUPINFO siStartInfo;
BOOL bFuncRetn = FALSE;
// Set up members of the PROCESS_INFORMATION structure.
ZeroMemory( &piProcInfo, sizeof(PROCESS_INFORMATION) );
// Set up members of the STARTUPINFO structure.
ZeroMemory( &siStartInfo, sizeof(STARTUPINFO) );
siStartInfo.cb = sizeof(STARTUPINFO);
// Create the child process.
bFuncRetn = CreateProcess(NULL,
"child", // command line
NULL, // process security attributes
NULL, // primary thread security attributes
TRUE, // handles are inherited
0, // creation flags
NULL, // use parent's environment
NULL, // use parent's current directory
&siStartInfo, // STARTUPINFO pointer
&piProcInfo); // receives PROCESS_INFORMATION
if (bFuncRetn == 0) {
ErrorExit("CreateProcess failed\n");
return 0;
} else {
CloseHandle(piProcInfo.hProcess);
CloseHandle(piProcInfo.hThread);
return bFuncRetn;
DWORD dwRead, dwWritten;
CHAR chBuf[BUFSIZE];
// Read from a file and write its contents to a pipe.
for (;;)
if (! ReadFile(hInputFile, chBuf, BUFSIZE, &dwRead, NULL) ||
dwRead == 0) break;
if (! WriteFile(hChildStdinWrDup, chBuf, dwRead,
&dwWritten, NULL)) break;
// Close the pipe handle so the child process stops reading.
if (! CloseHandle(hChildStdinWrDup))
ErrorExit("Close pipe failed\n");
HANDLE hStdout = GetStdHandle(STD_OUTPUT_HANDLE);
// Close the write end of the pipe before reading from the
// read end of the pipe.
if (!CloseHandle(hChildStdoutWr))
ErrorExit("Closing handle failed");
// Read output from the child process, and write to parent's STDOUT.
for (;;)
if( !ReadFile( hChildStdoutRdDup, chBuf, BUFSIZE, &dwRead,
NULL) || dwRead == 0) break;
if (! WriteFile(hSaveStdout, chBuf, dwRead, &dwWritten, NULL))
break;
VOID ErrorExit (LPTSTR lpszMessage)
fprintf(stderr, "%s\n", lpszMessage);
ExitProcess(0);
// The code for the child process.
VOID main(VOID)
HANDLE hStdin, hStdout;
BOOL fSuccess;
hStdin = GetStdHandle(STD_INPUT_HANDLE);
if ((hStdout == INVALID_HANDLE_VALUE) ||
(hStdin == INVALID_HANDLE_VALUE))
ExitProcess(1);
for (;;)
// Read from standard input.
fSuccess = ReadFile(hStdin, chBuf, BUFSIZE, &dwRead, NULL);
if (! fSuccess || dwRead == 0)
break;
// Write to standard output.
fSuccess = WriteFile(hStdout, chBuf, dwRead, &dwWritten, NULL);
if (! fSuccess)
break;
You can use this code snippet out of all mfc-code to start a childprocess... it works ...
implementation:
#include "stdafx.h"
#include "ORProcessMgr.h"
CORProcessMgr::CORProcessMgr(void)
m_bProcess = FALSE;
m_sProcName.Empty();
m_sCmdLine.Empty();
m_hwndWnd = NULL;
ZeroMemory(&m_si, sizeof(m_si));
m_si.cb = sizeof(m_si);
ZeroMemory(&m_pi, sizeof(m_pi));
CORProcessMgr::~CORProcessMgr(void)
if(m_bProcess == TRUE)
StopProcess();
void CORProcessMgr::Init(CString sProcName, CString sCmdLine)
StopProcess();
m_hwndWnd = NULL;
m_sProcName = sProcName;
m_sCmdLine = sCmdLine;
BOOL CORProcessMgr::StartProcess(void)
char * pCmdLine = NULL;
if(!m_sCmdLine.IsEmpty())
pCmdLine = m_sCmdLine.GetBuffer(m_sCmdLine.GetLength() + 1);
m_sCmdLine.ReleaseBuffer();
LPCTSTR pProcName = NULL;
if(!m_sProcName.IsEmpty())
pProcName = (LPCTSTR)m_sProcName;
if(!pCmdLine && !pProcName)
return FALSE;
// Prozess starten
if(!CreateProcess(pProcName, // Modulname
pCmdLine, // Kommandozeilenparameter
NULL, // Vererbung Processhandle
NULL, // Vererbung Threadhandle
FALSE, // Vererbung unterbinden
0, // Creationflags
NULL, // Environment-Block
NULL, // StartVerzeichnis
&m_si, // Startup-Info
&m_pi)) // Process-Info
CString sErrMsg;
sErrMsg.Format("Konnte Prozess %s nicht starten !", m_sProcName);
AfxMessageBox(sErrMsg, MB_OK | MB_ICONERROR);
return FALSE;
m_bProcess = TRUE;
return TRUE;
void CORProcessMgr::StopProcess(void)
if(m_bProcess == FALSE)
return;
::CloseHandle(m_pi.hProcess);
HANDLE process = OpenProcess(PROCESS_TERMINATE, 0, m_pi.dwProcessId);
::TerminateProcess(process, 0);
Sleep(400);
m_bProcess = FALSE;
the class header:
#ifndef __ORPROCESSMGR__
#define __ORPROCESSMGR__ 1
class CORProcessMgr : public CObject
public:
CORProcessMgr(void);
~CORProcessMgr(void);
BOOL StartProcess(void);
void StopProcess(void);
void Init(CString sProcName, CString sCmdLine);
BOOL m_bProcess;
protected:
HWND m_hwndWnd;
STARTUPINFO m_si;
PROCESS_INFORMATION m_pi;
CString m_sProcName;
CString m_sCmdLine;
#endif
Much luck and success ... dlawedor[/b]
In the middle of every difficulty lies opportunity. Albert Einstein -
Obviosly I'm no expert at this, but why does it take
so much code to start another process
doesn't spawn() jut do it in one line ? -
And most of the code is beacuse of security reason.You don't really want to give some unknown proccess all the rights, don't you? -
Baldrick ... I think it would be a nice thing to offer a own forum-section for those questions (programming or lets say developing something) ... so it is easier to search for and to find it ... what do you think about it !!! :P dlawedor
thanx, dlawedor
good advice wanted when using Cinegobs Keyer
By snafubaby in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2011, 05:58 -
Software Advice Wanted
By CthulhuSaves in forum DVD RippingReplies: 3Last Post: 16th Feb 2011, 13:25 -
Advice wanted on setting up Civic Webcam
By ahhaa in forum ComputerReplies: 3Last Post: 8th Jan 2010, 13:30 -
Wanted: some pro advice on a good topology for live streaming
By ktstowell in forum Video Streaming DownloadingReplies: 2Last Post: 27th Mar 2009, 12:07 -
Wireless Storage Advice Wanted
By tmw in forum ComputerReplies: 12Last Post: 1st Mar 2009, 16:47
