I converted vcd files to dvd files using tmpgenc plus and then authored using tmpgenc author.
There are half the files missing on my dvd-r. Could it be that the vcd-mpeg1 files had errors or what?
Results 1 to 13 of 13
1.) You need to give this much more than a couple of hours to expect a reply. Wait a few days. We all have to many times.
2.) If you want any useful answers you need to provide way more information. File types, conversion method, what files do you believe are missing?, what files are included?, etc. etc. etc.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
I got a music vcd with avseq.dat files on it.
I used vcd gear to change to mpeg files. I then used tmpgenc plus to convert dvd (mpeg2) files with the ES(video+audio) option. This saved the mpeg2 and mp2 files seperately in a folder.
Then I went to tmpgenc dvd author and added files and created a menu. Then I copied the dvd folder to my hard drive and went back to tmpgenc dvd author and copied the dvd folder to a dvd-rw before doing it to a dvd-rw.
Now, I played the dvd in my computer and on dvd player. The dvd has 22 songs and I put 6 songs per page for the menu. Only the first 6 appeared and the last 4 appeared on the dvd. Why would this be?
QUESTIONS
1. Should I have selected "Fix Mpeg errors" when converting in vcd gear?
2. Should I have done a different option in tmpgenc plus rather than "ES (video+audio)?
3. Should I make iso files to hard drive in tmpgenc dvd author and then put the iso files on the dvd-rw? -
Hey,
Maybe you should consider to author the vcds with tmpgenc author to a dvd without encoding. Gives you a few advantages but also some disadvantages
pro:
- you can put more vcds on 1 dvd
- you don't get quality lose by reencoding
con:
- you need reencode your audio to 48khz (you an use svcd2dvd to do that in batch, it can even create your dvd's if you buy the program)
- your dvd player needs to play vcd-dvds.Greatings,
Yf -
Yes the DVD play sometimes doesn't work.
It used to. dunno what happened. anyway
You open VTS_01_0.ifo
If you double click on things under PGC_1 it will
show the clips in a window.
You can check for a reasonable play time and lots of other stuff
You can also play the DVD files while they are still on the computer
with WIN DVD to see if the burning process was at fault. -
Luke23,
Since you will gain nothing and potentially make the video worse, I'd recommend keeping the video at VCD specs. VCD video is also a valid DVD spec. The only thing you need to do is convert the audio to 48k and you can fit as many as you can on the DVD, as someone else has mentioned.
I do this all the time with TV episodes. Capture in VCD, convert audio and then author to DVD. ANY dvd player should play them if they meet dvd specs. I happen to use Ulead MF2 since it will author the DVD with simply setting it to not convert the video and letting it convert the audio. This is just fine for episodes. For music videos, you may want to use something better to maintain the audio quality as close as possible. I use besweet for best results.
So, here's what to do:
- Get VCDs
- Demux
- Resample audio to 48k
- Remux
- Author DVDHave a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
missing converted files
By chucksupple in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2012, 16:25 -
converting DVD mini disk files to compatible APPLE format- video is missing
By MovieMom in forum Video ConversionReplies: 2Last Post: 5th Sep 2010, 14:33 -
missing some DVD files copied to disk
By snafubaby in forum Authoring (DVD)Replies: 0Last Post: 31st Jan 2009, 01:26 -
vob files now missing
By flyingrrt in forum DVD RippingReplies: 2Last Post: 20th Dec 2007, 13:35 -
Missing files
By justinguitar in forum ffmpegX general discussionReplies: 5Last Post: 25th May 2007, 19:40
