Results 1 to 14 of 14
  1. Anyone else use this for realitme mpeg2 encoding? The best I can do is high quality VCD using the dvd setting. I even tweaked the settings to the max some times.
  2. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    Someone else mentioned that they had tried it. Just do a search. If I remember that person had a really fast machine!
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  3. Yep - I've tried it, but to be fare ,only on a ten minute clip just to see how it performed. Captured at 720x576 no frame drops.
    Quality not bad but I didn't think as good as ati MMC. Having said that I didn't tweak the settings too much so somebody more patient that me might give you a better review.
    I might be that your capture card is the deciding factor not the software itself.
    Jan 2003
    India
    PAL-720x576 capture-with PCM audio-no dropped frames-setting is MPEG2- no other special tweaking-highest bit rate available (8000 kbps VBR)
    Using mpeg layer II for audio-there were a few dropped frames. BTW-I always use PCM-whether for avi or for mpeg2 captures. For some strange reasons, I get dropped frames when I compress the audio while capturing.
  5. Hi,
    I got dropped frame like crazy, so considering my cpu is P4 1.6, it maybe due to the speed of my computer. then I enabled the buffering option but it was no longer real time. I also noticed that there was no option to make 1 or 2 pass encoding when you choose MPEG2 capturing. Did I miss something or actually there is no 2 pass option while capturing/encoding real time. One more thing, is there any difference between the quality of real time capture and encoding to MPEG2 from a DV file assuming in both cases the source is a digital cam? Thanks.
  6. 2 pass real time encoding.. no, it cannot be done unless time travel has been invented. you could encode real time at high bitrate then re-encode for a lower average bitrate. My capture software from leadtek (PVR) allows me to capture in svcd realtime, but quality is not great. probably needs more tweaking than I can give it.
    IMHO : cpu is the big bottleneck in capture not disk thruput so compressing audio is extra cpu burden ergo dropped frames, mgh
    The electronic components of the power part adopted a lot of Rubycons.
  7. I have a p4 2.2 and I still get a ton of dropped frames but I'm willing to guess that's because of my hard drive but the problem I'm also experiencing is the quality. I guess you need a 3 Ghz or a hardware encoder if you want it to look good.
  8. I think your processor is fast enough and as long as you are capturing to a non system disc you should be ok. I don't know much about your capture card but from what I've read they are pretty good so...........Have you got a seperate sound card or do you use onboard sound?
    Again from what I have read this can make a big difference. Might be on the wrong tack there though.
  9. I have onboard sound and I am capturing to a seperate hard drive but it hasn't been defraged for a while. Now that I'm looking at my satellite feed on my monitor I noticed that's it's not really the encoding that's the problem. The encoder is simply capturing what is displayed and that's actually the real problem. For some reason the capturing I see a lot of pixelation capturing straight from my direct tv thru the svideo input.
    Rio de Janeiro - Brazil
    I just tested this Mainconcept 1.4 Capture. I was able to capture 704x480 at 6000 VBR MPEG2 only if I disable half frame pel or something like that (I can the exact option later), doing MP2 audio at the same time. I can't get to 720x480 without getting dropped frames, even switching to PCM. My Tweaked 704x480 took between 85%-98% of CPU processing.
    An interesting Data: when capturing at 352x480, I was able to do other things while capturing a good VHS take with no framedrops. CPU was between 65%-75%. I just set Mainconcept to High Priority and could capture in Realtime in background!
    I have an Atlhon 2000+, 256 Mb SDRAM, 40 Gb 5400 rpm Maxtor HD and a motherboard K7S5A.
    []'s
    VMesquita
  11. Video Restorer lordsmurf's Avatar
    Probably never will either. ATI AIW Radeons and the ATI MMC use Ligos GoMotion in a hardware-assist variation. This MC capturing, though some I've not yet tried it out, is pure software. I'll try it if a trial version exists. And if it works, I'd probably even make a guide.
    What a coincidence, LordSmuf, I just visited your page and mailed you asking your oppinion about some stuff, including MainConcept 1.4 capture. There's a Demo version available in mainconcept homepage.
    []'s
    VMesquita
  13. I agree with RabidDog.
    A 60 minute DVD 4.7G is only about 4.482G in computer bytes.
    4482MB/60min= 74.5MB/60sec=1.125MB per second. If we capture MPEG2 in real time and expect to put it on a DVD then our hard disk drives must be up to writing 1.125MB per second. Thats not much.
    it's not the drive.
    The problem is definatelly CPU. hhamzeh is probably trying to capture fullD1 (720x480/576) and his p4 1.6 is not up to the task. I have an Atlhon 2000+, that should have a performance similar to a P4-2.0 (altrought it runs at 1.666) and can't do it. The limit for me is 704x480 with that option off.
    []'s
    VMesquita
