Hi everyone,
First of all this is a great forum and I have learned a lot form the guides here and reading the posts in the areas that I need to learn.
I have captured some movies from Sat with my ATI AIW 9000 in dvd format and burned them to -r or -rw with menus and sound using dvd movie factory2.
Now, this is fine but most of the movies I have done are 1 hour and 30 mins to 1 hour and 45 mins. What I would like to do is lower the video bit rate to fit 2 movies on a -r keeping the 720X480 dvd format.
At the moment I am attempting this but I was wondering what the best compression settings are to get aprox 3hrs 15 mins of video and audio on a disc??
The project that my other machine is rendering right now using Movie Factory2 is 720X480 @29.97 NTSC 3000 kbs max variable bit rate with MPG audio. I hope I got all this right, as I said above I am new to this LOL.
I assume there is a lot of trial and error involved to get the desired record time with decent quality but, I am wondering what settings others use to create similar dvds from sat captures?
Jamie
If I were you, I would do a test capture at 352 x 480
and around 3000kbps and see if the quality looks oK to you.
3.5 hours is pushing it and 352 will help lots at low rates.
If you know how long the movies are you can calculate what bitrate
to use with one of the calculators. ....and if you go over a little
you can use DVDShrink to fix it easily
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 03:27 -
Best Sat finder?
By snadge in forum DVB / IPTVReplies: 0Last Post: 22nd Dec 2008, 10:03 -
Delayed subs: record from sat, crop in Shrink, burn to dvd, play
By Mudd in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2008, 04:23 -
Sat tv with a tv tuner
By shkdwn in forum Newbie / General discussionsReplies: 2Last Post: 23rd Nov 2007, 12:12 -
DVD Recorder, The Tv and The Sat. Box (HELP)
By lostgoddess in forum DVD & Blu-ray RecordersReplies: 7Last Post: 5th Nov 2007, 00:17
