Set my variable high=2520, average=1800 and low=300.
where do u do all of that at?
Results 31 to 56 of 56
1st of all which TMPG are you using? The free one or the Plus version? If using Plus when you select 2 pass variable there should be a settings box click on it and thats where you change the settings.
would u happen to have AIM or yahoo messanger? cus i'm gettin tired of this
Nope, sorry. Too mant malicious scripts running out there. Are you using the freeware version of TMPG? Or did you pay for it?
https://www.videohelp.com/forum/userguides/119210.php
There's one guide that is almost like what I described. Just change it from constant quality to 2 pass vbr and click on settings next to it. If you are using freeware version that may be why you can't change it. -
Originally Posted by tmac2085Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
That's what Nero does unfortunately. It's a POS for making svcd's period. The ONLY thing I use Nero for is audio cd's. You're better off spending your money and getting a better program to burn with like Ulead MF2 that you can set to not encode compliant mpegs. All I got from Nero was headaches and coasters for video.
Now that's just from my own personal use. It took me alot of time, effort, patience and a few spindles of blanks to get it right but now for me, I use Dr. Divx, then Virtualdub, then TMPG and finally burn with Ulead MF2. Seems alot of steps but the quality has been superb, no lines, pixels and audio perfectly synched. I'd go to Uleads site and check it out 1st and see if it's something that you think you'll use before spending the $$$. Just under no circumstances should you ever let MF2 encode because it stinks at it.
No offense dude, but you need to do some READING. This is really BASIC stuff and it's all in the GUIDES.
1st off, are you encoding to mpeg2? If not, you need to be. Remember, SVCD is mpeg2.
PAL
Video:
max 2600 kbit/sec MPEG-2 (Audio + Video bitrate max bitrate is 2778 kbit/s).
480 x 576 pixels (CVD 352x576)
25 frames/second
with up to 4 Subtitles
Audio:
from 32 - 384 kbit/sec MPEG-1 Layer2
with up to 2 Audio Tracks
Extra :
Menus and chapters.
Still pictures 704x576,352x288
NTSC (NTSC Film)
Video:
480 x 480 pixels (CVD 352x480)
29,97 frames/second
23,976 frames/second with 3:2 pulldown (NTSC Film)
Audio:
Extra :
Menus and chapters.
Still pictures 704x480,352x240 -
Was trying to use easiest possible explainations as he didn't seem to be getting it. Geez!
4 People suggested VCDEasy
3 People suggested VCDImager
1 Person suggestd TSCV (I find it buggy for me)
1 Person suggested Prassi Prime
1 Person suggested Unlead MF2
Did you try any of these apps? You asked what people use, we told you but it seems like you are ignoring what we suggest and continuing to ask why doesnt it work.Ejoc's CVD Page:
DVD:
Capture:
used them all but Ulead MF2. some programs said i have no recorder. which i do.
DVD:
Capture:
Prassi Prime said i dont have a supported drive, but i do and its working fine. and i had no idea of how to use vcdeasy...sounds easy but not for me obviously...but i'm gettin the Ulead now and hopefully it wont tell me that i have a unsupported drive. and if it does i'll give up on everything.
There are 17 guides for using VCDEasy, you read them all and could get it to work at all?
Ejoc's CVD Page:
DVD:
Capture:
the ulead one is working. but when i encoded the mpeg-2 its more than 800 MB so i guess i gotta cut some out or somethin???
You dont know what a guide is?
I give up on this thread, this is a waist of timeEjoc's CVD Page:
DVD:
Capture:
Undoubtedly, the written guides will be more detailed and have better explanations on doing specific tasks than a general thread.
Look at the "How To" section (the green section) in the column on the LEFT.
There are many many guides there. Then, have a look at the user guides section of the forums. There are many guides there as well (ones contributed by forum members).
I personally believe that VCDEasy / VCDImager (VCDEasy uses VCDImager as a backend) is the best S/VCD authoring solution. This is attested by the other posters in this thread (the majority are suggest VCDEasy). You should persevere with this software.
Read the "What Is" sections on VCD and SVCD as well so that you actually know what you are trying to make.
https://www.videohelp.com/vcd
https://www.videohelp.com/svcd
Regards.Michael Tam
w: Morsels of Evidence -
Okay,
As Craig already stated (& finally after so many others posted yet did not hit upon) If he is trying to burn it as a svcd after encoding it as a vcd, & nero is trying to re-encode it, you must not be encoding it correctly to begin with in TMPGEnc , I have used many diff. versions of nero with no problems to burn vcd & svcd, i also use VCDEasy when i want to add chapter points, but VCDEasy will also give you a warning (not re-encode) a file if it was encoded as a vcd & you are trying to burn it as an svcd, or if is not compliant.
When encoding with TMPGEnc make sure you use one of the standard templates or use the wizard without changing any of he settings & you should have no problem burning either vcd or svcd. -
This thread is asinine.
Load the file into Nero.
He has countless times said Nero re-encodes it. DO NOT allow it to re-encode.
Just click "Turn off Compliance" or whatever the phrase is.
If it says the file is now too big, go back to TMGEnc and render to 2 disks.
No one can be as dense as TMAC is making himself out to be.
Two whole pages, and the thread is getting to the tech guy's remark to pack your computer back in the box and return it because you are too dumb to own a computer..
RTFM? How about RTFG (for Guides )
Cheers,
George -
what do you use to burn VCDs or SVCDs??SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
n00b saving in Ulead for svcds and dvds myspace
By dsound in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2008, 12:40 -
2.5.3300 SVCDs getting recoded
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 15th Oct 2007, 21:44 -
Winavi v8 SVCDs jerking with SVCD2DVD
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 13th Jun 2007, 16:02
