Is there a program that will make a black censored box in my video over a person who is walking in the frames (that is, the box would have to move or follow the person) or VDub filter.
I tried LOGOAWAY, but cause the person is moving, the box doesn't really cover what I want covered. THANX.
Results 1 to 17 of 17
The easy way would be a program like AfterEffects, where you could create a box that move along the path you specify, following and covering the 'nudity'. I've only used AE a few times, but its relatively easy to learn the simple stuff like what you want - there are lots of tutorials on the web.
I guess you could also render out the video into bmps and manually fix each one - but it would definitely be a big pain in the ass if the nudity is onscreen longer than a second or two. -
Digieffects delerium can be used in either AE or Boris FX. It has a specific filter to mosaic over what ever you want. The same as what they do for TV.
try http://www.alamdv.com its a great prog for doing light sabres etc, and its pretty cheap too
what's wrong with nudity???
Isn't it better to cut of the violent in movies instead of nudity? strange..... -
I tried those programs and they were either $$$$ or too complicated. Is there any other ways? With Adobe Premeire maybe? Help.
Once again why would u want to remove nudity? r u showing it to your parents or younger children or something? Because u can try to download the same file (unless it is a home video) from a program like filetopia or winmx. Anyway good luck finding it
I WANT TO SHOW A MOVIE CLIP ON MY WEBSITE, BUT IF THERE'S NUDITY, I'LL GET KICKED OFF MY HOST... AND I NEED TO SHOW AS MUCH OF THE CLIPS DETAIL AS POSSIBLE SO EDITING OUT THE ENTIRE FRAMES IS NOT AN OPTION! NOW HOW DO I COVER THIS STUFF UP? I TRIED ALAMDV, BUT MY SHIT MONITOR DOESNT HAVE ENOUGH RESOLUTION TO SUPPORT IT. I JUST GOT ADOBE AFTER EFFECT NOW HOW DO I UST THAT?
Now now, raising on'es vioce will never solve anything... As one of the previous posters stated, there are many AE tutorials on the net, asking for someone to explain how to use it in a post is simply pointless, it would be much too long.
Dont know if this will work, but since you have Premiere anyway...Can you use a piece of moving text which is carefully positioned and moves along with the area you want to censor. The path definition for moving text is pretty powerfull in premiere so with a little messing about, you should be able to get the desired result.
just a note to say alamdv have released a patch which will solve the resolution problem
By never thought of that moving text on a path. That would work good. Just like you see on that "Blind Date" with the word "CENSORED" on the mouth or body parts. That would work.
I use Studio (Pinnacle) for all kinds of overlaying tasks (images, text etc...).
What you want to do can easily be accomplished with studio.
Try VirtualDub. It has shloads of filters. One of them is a "Fill" and you can select a section and set the size and upper left and your good to go.
Cheers,
Mike
I tried fill filter, but since the person moves in the video, I would have to cover half the screen... so that's not an option. Are there any other filters that can do this?
Is there any other EASY to use software that can do this? Like something from MGI or sumthin else with a demo?
How to put black colour on screen without re-encoding?
By swalih in forum EditingReplies: 6Last Post: 16th Feb 2012, 03:44 -
How to get rid of black letterbox borders on AVI file?
By mukluk909 in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2010, 15:18 -
Black Box Problem
By alimustafakhan in forum SubtitleReplies: 0Last Post: 25th Aug 2010, 07:55 -
Adding black box behind subtitles in Divxland Media Subtitler
By reutc in forum SubtitleReplies: 0Last Post: 3rd Sep 2008, 11:05 -
How to put thick black border around video?
By skylights in forum Newbie / General discussionsReplies: 6Last Post: 29th Apr 2008, 09:24
