  1. I'm backing up "Sex and the City". I wanted to keep the menus but delete the extras. I'm trying CloneDVD for the first time. I couldn't figure out how to remove the FBI warning. Is that possible?
    When I select a menu item for material that was removed I get an obnoxious flashing green screen that goes on and on. Is that normal?
  2. Banned
    May 2003
    Massachusetts
    The screen should be grey, not flashing green, but yes that's normal.
    You can't remove the fbi warning, unless it's in its own title.
    - Gurm
