My panasonic SA-PM08 dvd player only plays riteks - it hates everything else! They just glitch...
Anyway at a pc market, I asked for my trusty ritek disks and I got handed a pack I've not seen before - O1NE's - sliver top, 4x ver2..
He told me they are good and riteks...
I burn my first movie and my player came up 'Read Error' - after 3 try's it started playing with the worst glitching I've ever seen.. I checked in DVDDecrypter and it said the disks were LEADDATA01 were it would normaly say ritek...
After checking the reviews they all say this disk is great, and the O1NE web site says the dye is ritek... please can someone explain... Thanks
Results 1 to 11 of 11
Here's your solution--buy another dvd player. They are almost at giveaway prices these days.
A kiss on the hand might be quite continental, but tactical nukes are a boy's best friend -
aerodeck,
I agree with Boffo. Try the cheapo Chinese DVD (i.e. Apex, Norcent). They can almost play everything and they are only in the $50 range. Amazon.com sell the Norcent DP-302V for only 49.99 + S&H and with a $10 rebate, it's down to $39.99 + S&H. -
Return them and tell the bloke that sold them to you he is mistaken. And you want a refund.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
This is a follow-up on my last post... Just check the Amazon.com web page, the Norcent DP-302V qualifies for free S&H, and so I guess the bottom line price including the rebate is $39.99. That's cheaper than a 50-pack of DVD.
Return the media (you got screwed) but it is time to get a new DVD player. I personally really like my Cyberhome 500 (but then I rent/own a lot of PAL and non region 1 discs).
There are a ton of 'cheap' players out there that play almost anything. That's because they are really PC DVD-ROM drives with an external case. So they'll play DVDR, VCD, SVCD, CVD, minDVD, MP3, JPG, etc. Hell a few will even play raw MPEG1 or MPEG2 video just dumped on media. -
I agree - get a new player.
I was in the same situation a few weeks ago. I had an LG player which would quite often skip on DVDRs (regardless of brand). I tried burning at 4x, 2x, 1x, but no difference.
Eventually I went out and bought a new Pioneer DV-466 player, which even had a "DVD-RW" logo on it, and it plays everything the LG wouldn't.
The peace of mind is definitely worth the money I paid for it! -
hummm, a new dvd player is not an option. The panasonic cost me about 500 pounds when I got it new, it includes the 5.1 speakers which sit perfecly on my fire-place. The sound is amazin.... Anyway the disks have great trouble playing in my Dansai, which is meant to play everything.
They also won't play in 2 DVDRom drivers in my 2nd pc... I'll just stick to ritek's...
I'm more confused than upset as to the great reviews this disk has got...
Cut my loss's. -
My Sony is very picky about media too - Ritek is its favorite as well.
However, saying that, the following work very well too... it might be worth you trying these if you haven't already.
Nan-ya
e-Proformance (Pro-disc)
Datawrite Classic (with the fake TDK codes, not the "new" lot)
TDK (real)
Places like http://www.blankdiscshop.co.uk and do sample packs for not a lot of cash which might offer you a few unexpected surprises !
Good luck. -
My Norcent DP300 doesHell a few will even play raw MPEG1 or MPEG2 video just dumped on media.
Heck why make a VCD when I can dump a Mpeg1 file right to CD and play it just fine
I also dumped a Mpeg2 to DVD and it played fine till it hit a file size limit it looked like then stopped. But a full disk of 1gig and maybe 2gig mpeg2 files plays em all.
You should print the disk info screen and take it with you and get a refund!
If you were told those were riteks, you bought them as riteks, and you have the printed proof they are LEADDATA01 and NOT ritek, you should not have much problem getting either your money back or real riteks!
If they give you any arguements I would never shop there again, but if they make it good I might condsider it possibly an honest mistake.
If they say well the dye is ritek, tell em so what the disks are not!
And they don't work, but riteks do! -
My Phillips 726 as does this as well.Hell a few will even play raw MPEG1 or MPEG2 video just dumped on media.
my brain hurts - converting SSA to something DVDAuthorGUI can understand?
By EddyH in forum SubtitleReplies: 17Last Post: 26th Apr 2010, 10:11 -
How to change 720x480 to 640x360 resolution (I'm going to cry :( )
By tutti456 in forum Video ConversionReplies: 4Last Post: 2nd Mar 2010, 10:03 -
Psst... it never hurts to spread the word...
By MeDiCo_BrUjO in forum Off topicReplies: 0Last Post: 1st Aug 2008, 11:53 -
Which player do I get? my head hurts!
By Castor troy in forum DVD & Blu-ray RecordersReplies: 7Last Post: 13th Apr 2008, 17:18
