Results 1 to 12 of 12
  1. I just burned a dvd to dvd+r and tried to play it but when i do it says....Error: code 89020003 The DVD might have been damaged so as to inhabit playback operation...help?
    Mar 2003
    Uranus
    Let me look you up in my remote radar that watches
    everything everyone does so I can determine what
    hardware, and software, and procedures you have.
  3. I think what he's saying m8 is provide some details and someone might be able to advise you.
    What you've said above is a bit like saying "my car wont start .... what could it be ?"
    Jul 2002
    Scotland
    My crystal ball says you burned the disc with Nero 6 and tried to play in power dvd. Does it play okay in a stand-a-lone ?
    Solution - Go back to Nero 5.5 or use another burning program. Copy2DVD is stable and easy to use.
    dlb.
  5. ahah sry...i used a HP dvd+ writer 300i and used CopyToDVD to burn the DVD...it was only about 3gig...so i didint shrink it or anything i just str8 up copied the dvd...im a n00b at this...2nd day...i do have nero 6 and dvd shrink tho...if that helps ne...
  6. o yea...i did use powerdvd...does that suck or sumtin?? what should i use?
    Jul 2003
    Hampshire, UK
    Er, why bother to use Power DVD to play back, when Nero 6 has its own player built in. i can't say I've extensively tested it, but it seems to work OK, both on pre-recorded DVD's and home burnt DVD's (burnt with Nero 5 and 6, and Ulead Videostudio). Does it work on Nero's own player, or is there a conflict beteen the two?
    William
  8. I used to get that error with my old DVD-ROM drive - it found it virtually impossible to play back recordable media regardless of manufacturer.
    Try playing it back on another drive - like the recorder, maybe, and see if that works.
    Jul 2003
    michigan
    ive been reading some of the forums, and that foo guy is really grumpy. he really needs to get over the spice girls breaking up
    Mar 2002
    Manchester, UK
    Oi! He's nothing to do with me!
    Mar 2003
    Uranus
    That needs to go in the Grumpy People forum.
    Besides what would you have told the original poster ?
    Just a little sarcastic humor
    May 2003
    Pal Realm
    I think ricky did what I did. :co Read 3 of yours in a row.
    If I'd only seen one, I would have laughed, but after 3 I thought you'd had a terrible, miserable, horrible day or got some really bad news.
    Glad to know you were just being Foo-y.
    :c)
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
