today i tried to make a southpark dvd with 12 svcd eps, when its done its seems 4 eps are missing, there are only 8 vobs, one of the eps has this error:
svcd2dvd creates a .xml file with this error in it:
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
A semi colon character was expected. Error processing resource 'file:///F:/tv/dvd/south_park_s02e01_terrance_&_phillip_in_not_withou t_my_anus_dvdrip_svcd_teve_info.xml'. Line 1, Position 107
<mpeg-info src="F:\tv\dvd\south_park_s02e01_terrance_&_philli p_in_not_without_my_anus_dvdrip_svcd_teve.mpg">
and the other 3 eps are just missing, i dont see any errors in the logs. they get multiplexed but after its done the *_dvd.mpeg file dissapears.
i noticed this:
File: F:\tv\dvd\south_park_s02e01_terrance_&_phillip_in_ not.mpg
Horizontal Res: 0
Audio SampleRate: 0
looks like it cant read the resolution/samplerate
the xml error is just due to your xml viewer (internet explorer?).
I would need to see your log file (configuration menu> Show log...) to help with this.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
i tested svcd2dvd with 2 musicvideos(svcds) and again it skips on of the mpeg files
i got 2 svcds:
Rakim_Guess_Whos_Back_SVCD_1997_UVZ.mpg
panjabi_mc_beware_of_the_boys_(remix_audio_ft_jayz )_(svcd_2003)_kvz.mpg
after svcd2dvd is done i only have:
Rakim_Guess_Whos_Back_SVCD_1997_UVZ_DVD.mpg
i have this problem alot, it just dont create the other _DVD file, same with the southpark eps, i put 12 svcds in the dir and it only creates 8 _DVD files, and i cant find a error in the log:
take a look:
Starting SVCD2DVD: v1.5.1360.18182
Begin time: 21:10:56
******** Ripping SVCD images to get mpegs
Analysing File: E:\incoming\New Folder\Rakim_Guess_Whos_Back_SVCD_1997_UVZ.mpg
Analysing File: E:\incoming\New Folder\panjabi_mc_beware_of_the_boys_(remix_audio_ ft_jayz)_(svcd_2003)_kvz.mpg
-->Processing 2 mpeg files.
############### New MPEG File ###############
Horizontal Res: 480
Audio SampleRate: 44100
******** Demultipexing original mpg file
******** Resampling audio from 44.1 KHz to 48 KHz
******** Multipexing elementry streams
Analysing File: E:\incoming\New Folder\Rakim_Guess_Whos_Back_SVCD_1997_UVZ_DVD.mpg
Horizontal Res: 480
Analysing File: E:\incoming\New Folder\panjabi_mc_beware_of_the_boys_(remix_audio_ ft_jayz)_(svcd_2003)_kvz_DVD.mpg
******** Creating DVD...
Creating VTS #1
============ Complete ============
============ Duration: 00:01:29.1250000 -
from that output (its not the log file i needed) i see:
being turned intoCode:E:\incoming\New Folder\Rakim_Guess_Whos_Back_SVCD_1997_UVZ.mpg and E:\incoming\New Folder\panjabi_mc_beware_of_the_boys_(remix_audio_ft_jayz)_(svcd_2003)_kvz.mpg
can you check this & send me the log:Code:E:\incoming\New Folder\Rakim_Guess_Whos_Back_SVCD_1997_UVZ_DVD.mpg and E:\incoming\New Folder\panjabi_mc_beware_of_the_boys_(remix_audio_ft_jayz)_(svcd_2003)_kvz_DVD.mpg
damn it still got problems
when i wanna create a dvd with these svcds:
south_park_s02e01_terrance_&_phillip_in_not_withou t_my_anus_dvdrip_svcd_teve.mpg
south_park_s02E06_the_mexican_staring_frog_of_sout hern_sri_lanka_dvdrip_svcd_teve.mpg
south_park_s02e11_roger_ebert_should_lay_off_the_f atty_foods_dvdrip_svcd_teve.mpg
here is my log http://members.home.nl/187/svcd2dvdlog.txt
i dont get any *_DVD.mpg files, and the VIDEO_TS dir is empty , here is a screenshot when svcd2dvd is done:
this is the other log file
Begin time: 8:51:48
Analysing File: F:\tv\south_park_s02e01_terrance_&_phillip_in_not_ without_my_anus_dvdrip_svcd_teve.mpg
Analysing File: F:\tv\south_park_s02E06_the_mexican_staring_frog_o f_southern_sri_lanka_dvdrip_svcd_teve.mpg
Analysing File: F:\tv\south_park_s02e11_roger_ebert_should_lay_off _the_fatty_foods_dvdrip_svcd_teve.mpg
-->Processing 3 mpeg files.
Horizontal Res: 0
Audio SampleRate: 0
Analysing File: F:\tv\south_park_s02e01_terrance_&_phillip_in_not_ without_my_anus_dvdrip_svcd_teve_DVD.mpg
Horizontal Res: 480
Analysing File: F:\tv\south_park_s02E06_the_mexican_staring_frog_o f_southern_sri_lanka_dvdrip_svcd_teve_DVD.mpg
Horizontal Res: 480
Analysing File: F:\tv\south_park_s02e11_roger_ebert_should_lay_off _the_fatty_foods_dvdrip_svcd_teve_DVD.mpg
Creating VTS #1
============ Duration: 00:11:13.0937500 -
The log make interesting reading:
i think won't fly. There is something wrong with the mpg. (you could try vcdeasy mpg analyser to find out more)
the other two i think are falling over because of the length of the filename. Can you humour me & rename them to south_park_s02e01.mpg etc and try those other two - on their own - again. If this proves to be the case I'll investigate.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
Joining .VOB files to avoid skips
By logika in forum EditingReplies: 2Last Post: 27th Nov 2011, 15:28 -
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 07:04 -
LG BD 390 Jumps skips files
By trasker in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Oct 2010, 10:59 -
MENCODER skips frames when dealing with MPEG-2 audio
By zuja9 in forum Video ConversionReplies: 2Last Post: 19th May 2007, 16:12
