i am using tmpeg to encode my avi files to mpeg. a can get it to convert ok and burn ok. the problem is the colour. when i play the avi file through divx or windows media player the quality is great, but when i encode it through tmpeg, the colurs keep changeing from like a red effect to a blue effect, the the picture quality is ok.
please can you help
thanks
tracy
Results 1 to 14 of 14
just wondering ...have you solved your poblem cause i have the same one...i tried cce,tmpge but it's allways the same...blue red picture and the quality is fine.
what did you do?
thanks
evish -
anyone with the same problem?
come on people...
i use cce 2.50,and so far there weren't any problems until now, i have all the right codecs installed, because avi file works fine, but after the conversion(avi to svcd) the picture gets red, blue...the colours are all wrong..but that only happens at certain avi files,not all.
why?
any idea?
help!!! -
Macrovision. If you downloaded the files, there is little you can do. If you are capturing the files you can use your capturing program to defeat the Macrovision. But until you give me more details, I had better stop here.
Hello. -
hi!
what do you mean by macrovision?
what should i do?
i'm not compeletely new at this,but so far i didn't have any problems.none whatsoever. i downloaded dvd2svcd,installed cce 2.50, and everything worked prefectly ok.until now...
for any further instructions i'd be forever grateful
thanks
evish -
well, i downloaded avi files,i didn't capture them from dvd.
so there's nothing i can do to stop the colour from turning blue?????
i thought macrovision is used to protect dvd's, not avi files... -
LoadPlugin("C:\PROGRA~1\DVD2SVCD\AVISYN~1.5PL\Mpeg2dec\MPEG2D~1.DLL")
LoadPlugin("C:\PROGRA~1\DVD2SVCD\AVISYN~1.5PL\AVIS YN~2.DLL")
AVISource("D:\filmi\ZASKON~1\1EUAAO~1.AVI",False)
ConvertToYUY2()
BicubicResize(480,480,0.0,0.6)
AvisynthSubtitler("D:\filmi\filmi\mapca1\Subs\","p ermsubs.txt")
Import("D:\filmi\filmi\mapca1\ResampleAudio.avs")
ResampleAudio(44100)
any ideas???? -
as i see it i already have that line to begin with...
what else is there to do?
sorry to be such a pain...
Can you play this script with media player? Just try playing the script with media player to see how it looks. Also there is a forum at http://www.doo9.org that is devoted to avisynth
This is so much fun! -
hello
me again,
yes i can play the file with windows media player, but the colours are all red and blue...strange, but the quality of the picture is ok,...
why do you think there are avysinth problems???
thanks for help...
anyone else?????
please--- -
Originally Posted by eva
VCThis is so much fun! -
after a while i didn't know what to do anymore...
i uninstalled everything and reinstalled the programes which i used before...and now it works..strange......
i might not ever know what the problem was...but at least it works now..
thanks for everyone's help.
How to put black colour on screen without re-encoding?
By swalih in forum EditingReplies: 6Last Post: 16th Feb 2012, 03:44 -
Colour Conversion problems with Avisynth
By wiseant in forum Video ConversionReplies: 6Last Post: 16th Mar 2011, 11:40 -
Problems with subtitle font and colour
By skp61 in forum SubtitleReplies: 5Last Post: 29th May 2009, 19:29 -
FFDShow Big Colour Problems
By Endemoniada in forum Software PlayingReplies: 3Last Post: 28th Feb 2008, 22:19 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
