i saved the sound as wav in virtual dub then used tmpgenc to make convert to mpeg2 then used tmpgenc dvd authoring to make a dvd but when i play it the sound starts to go out of sync about half way through the film but it was fine to start with can any one help please
Did you scan for bad frames yet? Does the sound drift slowly out of synch, or goes out suddenly?
Hello. -
If it gradually goes out of synch with the video :
EG it plays fine at the beginning, but by the end is obviosuly not in synch, or as you say, after checking half-way, its obviosuly out of synch
Check out the guide on here that claims to cure gradual audio desynch, which is what it sounds like you are gettings
It certainly sounds easier and quicker than some of the other guides on trying to fix gradual audio desynch
Not tried it myself yet though
Do a search in the guides for something like gradual loss of audio synch that should find it -
Here is the link to that guide on curing Gradual audio synch
https://www.videohelp.com/forum/userguides/140540.php
Audio out of sync when converting from MKV
By carlmart in forum Video ConversionReplies: 8Last Post: 22nd Dec 2012, 17:07 -
HELP!!! converting RM to AVI, but now A/V out of sync
By ericdunn in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2010, 19:02 -
Audio is off sync from video after Converting?
By PHNeedsHelp in forum Authoring (DVD)Replies: 1Last Post: 23rd Nov 2009, 18:19 -
help tried everything to sync audio when converting to mp4
By modo2007 in forum Newbie / General discussionsReplies: 6Last Post: 14th Sep 2007, 11:23 -
By modo2007 in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2007, 14:09
