Is it possible to get this program to output one big mpeg2 file so i can cut it myself without sacrificing any quality?
Yes.
Several ways. You can edit some INI files to allow CD sizes of 2.4 or 3.2 GB. You can also not delete files. You will have the original M2V and MP2 files. Mux and cut to your hearts delight. I do this for my favorites, so I don't have to change disks in the middle of an action scene. Look in the 'Video' folder in DVD2SVCD folder, all the files are there.To Be, Or, Not To Be, That, Is The Gazorgan Plan
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
