  1. I don't know the differences between brands, how do I tell a better "CDR" than another? One that'll last longer is what I mean by better.
  2. Well stay with names brands just like in tapes, TDK, Yamaha, SONY, Memorix, Verbatim, Maxell, Pioneer.
    I usually use the 74min. only for music I try to stay away from the 80min. since its not within the original limits set up CD's.
    I use 80min. and 99min. CD-R's for VCD/SVCD's though.
  3. You need to check which color your cd, dvd and car stereo is compatible with.
    I've always used the pack of 100 generic. OK so far.
    I talked to a disc vendor a while back and he said no difference in quality, just color. Myself, I stay away from blue.
  4. Interesting link on media "goodness".
    http://www.cdmediaworld.com/hardware/cdrom/cd_quality.shtml
    This site:
    http://www.gum.de/it/download/index.htm
    has a nifty little utility to give you the "real" manufacturer of a CD.
  5. There is a HUGE difference, not based on color, rather the coatings used which determines the stability, longevity and duribility of the media. Cheap house brands simply don't hold up. You may get a good batch, then the next one may be crap. Not saying you can't get a bad batch with a name brand, by why increase your chances just to save a couple bucks? If you take the time to fiddle with quality as I'm guessing most do here, isn't your data worth a better brand of media?
