Hi. I see from the Pioneer site they have a new fimware upgrade for the 106 , R6FW107 has anybody tried it, if so what does it do was there any improvment. I got in touch with Pioneer but they say they do not publish details about there firmware.
not really any difference on anything bar maybe some disc compatibility.
if you have the 1.06,just stick with it just now,till more info is available.
that would be the safest bet. -
Yeah, stick with that for now, but use some of the hacks that will be coming from this site: http://forum.firmware-flash.com/viewforum.php?f=10
Soon you can burn cheap 1 x Ritek G03 at 2x and still be able to burn Ritek G04 at 4x. So really you just add options for yourself. Don't worry, if you dont like any firmware upgrade, you will be able to revert to your original version. -
This site has version 1.09. What is the real current version for a A06/106?
http://www.pioneerelectronics.com/pe/article/top/0,,2076_4257,00.html -
The firmware you were looking at was for the DVD-106, not the DVR-106. THe DVD-106 is a plain ol' DVD-ROM drive. It's really pioneer's fault for making them so simlilar in name.
Thanks for your help guys. I had another look on the Pioneer site (http://www.pioneer-eur.com/eur/support_software.jsp?category=support/software#fdvdwriter) and it said DVDR 106 firmware upgrade NOT DVD 106. I have not done any firmware upgrades tp my writer and I don't have any problems, I just wondered if there was any advantage to the latest upgrade.
Thespook
Pioneer DV-220V-K firmware
By totonionio in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Apr 2013, 09:45 -
Pioneer DV-S838A firmware
By zhudinglong in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Jul 2011, 02:12 -
Pioneer DV-220V-K firmware version?
By batyar55 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Jun 2010, 14:27 -
Pioneer DVD recorder firmware
By jh76 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Apr 2009, 03:03 -
Pioneer DVR-216 and Firmware
By dqtus in forum DVD & Blu-ray WritersReplies: 5Last Post: 27th Mar 2009, 03:26
