Hi I am trying to encode dv to vcd using TMPGEnc and the VCD template.
After encoding though the audio on the mpeg is very distorted and kind of in slow motion.
The original source is fine when played back on computer after transfering to pc.
What could be causing this? How can it be fixed?
When I try to open the file in Virtual dub i get the following error message "Couldn't locate decompressor for format 'dvsd' (unknown). Vitrual Dub requires a video for windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
What does this mean? -
For VDub you need a DV codec like the one from MainConcept/Panasonic/Sony or Adaptec.Search the forum or the web to locate this DV codec.dvsd is the infamous MS DV codec.Did you use Win XP for "capturing" from DV?
That seems to be one of the problems: using the standard DV capturing within XP doesnb't provide the proper DV codec.Use the Software, which came with your FW card or your DV device (if it's an external DV Bridge or similar device).You need in any case a DV codec, which is compatible with VDub (and other Video SW)
see here:
https://www.videohelp.com/forum/viewtopic.php?t=165837
Audio Sound Distorted
By Teac23 in forum Software PlayingReplies: 0Last Post: 1st Aug 2010, 07:40 -
Distorted sound wth FRAPS
By TheWHAMBurglar in forum AudioReplies: 0Last Post: 2nd Mar 2010, 01:54 -
REQ : - SOUND Distorted from footage
By mojoeuk in forum EditingReplies: 2Last Post: 23rd Nov 2007, 14:54 -
Distorted sound
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 17th Oct 2007, 18:40 -
distorted sound
By phillyrider in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2007, 06:25
