I bought a Verbatim DVD-RW disc that I've reburnt say 7-10 times.
Now, when I want to erase it, Nero says that it's not a rewriteable disc, so I messed up my expensive (ok,not that expensive: $5) -RW disc.
Is there a program or tool where you can "force" an erase of the disc.
Note that I've tried both quick erase and total erase.
The last burn I did was in Ulead DVDMovieFactory 2.0 and I chose "close disc" as an option. I had done this all the previous burnings too on this disc so that might not be the problem.
Any experiences on this matter?
Thanks alot in advance for reading this and, possibly, answering.
//Niclas
Results 1 to 11 of 11
the only alternative is to try different burning programs - try RecordNowMax for starters as that has never let me down - Nero has numerous times which is why I never use it now ...
Hope this helps.. -
I had same prob with few sony dvd-rw discs, nothing would erase them - while in the same time nero and other programs erased maxell and princo discs without any probs.
When i bought LG GMA-4020b burner it came with B's Clip software (for packet writing). I tried out its B's Erase program and it finally did erased those discs (BTW - the discs were burned as dvd-video, they were not formatted with any packet writing software etc).
Here is LINK, but I don't see there any downloadable trial version though :/ -
hello all,
im having the same problem, i cannot erase my (maxell) dvd+rw using nero (because the elapse time runs over and doesnt stop) and have just tried erasing it with DVDInfoPro.
The drive says, "CD drive(X", and has a little "DVD-ROM" icon on the disc image. When i right click on the drive and go to its properties it has no free bytes, its states the disc is full.
And i cannot write over it because of the reason i mentioned, it tells me that the disc is full.....
So i would appreciate any help at all to help solve this mystery. Thanks in advance for any replies... -
I had that problem until i figured what was causing it.Right click on your dvd drive then click properties.Then make sure that enabling recording on this drive is checkmarked that should do it.
Originally Posted by pantangs
Let you know when i try it out. -
apologies for taking as long as i did to post a reply....
I tried right clicking on the drive and checkmarking the enable recording and then used dvdInfo to try and erase the disc and it didnt work...
So back to square one, and still have no clue, anyway, i have two dvd+rw's that i got for free and have 50 dvd+r's, and so far have never had any problems with the +r's so i'll stick to write once discs.
If anyone can find a solution i would be imensely greatful, thanks in advance for any further replies and thanks to all you that did throw ideas out there...
have a good one everyone! -
I had that problem and the only way I could erase them was by using IMGBURN and doing a full erase. Nero nor TMPgenc DVDauthor would erase them but IMGBURN did.
IMGBURN is free btw. Click under tools-drive-erase disc then full. -
You can also try AShampoo burning studio 5.
Far faster than nero.
However, try doing a full-erase instead of a quick one. -
maybe the book type has changed once happened to me and Nero disc tool reformated it but nothing else would. as said just try every tool that can format the disc .
Is it possible to erase a DVD+R?
By Han Solo1 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2010, 13:54 -
How to erase a DVD-R disk
By bryankendall in forum ComputerReplies: 5Last Post: 24th Dec 2009, 13:16 -
DVD RW wno't erase
By jollyjohn in forum Newbie / General discussionsReplies: 5Last Post: 20th May 2009, 10:32 -
Can't erase my DVD-RW disc
By hurtstotalktoyou in forum DVD & Blu-ray WritersReplies: 4Last Post: 15th Nov 2007, 09:40 -
HELP - Can`t erase 10 dvd rw discs
By LOWTECH in forum DVD RippingReplies: 6Last Post: 13th Aug 2007, 14:28
