I am new to ripping, and have been using Smartripper and DVD Decrypter. I noticed that some vobs remain locked, causing errors in DVD Decrypter, and Smartripper prompts me to play the DVD with a software player to unlock it. Using Power DVD works sometimes, but not always. I bought the original DVD's and the DVD drive in the US, so I didn't think the region lock was an issue. What's going on, and how can I fix it?
Have a look at AnyDVD from Slysoft (trial copy)
You can then forget about SmartRipper & DVD Decrypter. -
As far as I understand it, region code has nothing to do with your problem.
The lock you're encountering is the copy protection system (e.g. CSS), rather than the region code - the latter tries to limit the distribution of discs to different geographical regions, rather than actually copy-protecting the disc.
I've always found SmartRipper can 'unlock' the disc eventually - I often use WinDVD rather than PowerDVD - have you tried this?
cheers,
mcdruid. -
I've used smartripper for about a year and then switched to DVD decrypter a few weeks ago. I can't say that I like one better than the other when it comes to ripping, but I did have to always play the dvd in my reader for a minute or so before smartripper could do it's magic.
I like DVD decrypter because of the ISO read / write feature.
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Newbie with Xbox - what s/w to rip DVD library @ highest sound/pic quality
By Snuker in forum Newbie / General discussionsReplies: 17Last Post: 13th Jan 2011, 12:37 -
newbie want to rip some vhs into DVD
By bambam in forum Capturing and VCRReplies: 5Last Post: 1st Jan 2011, 02:35 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28 -
NEWBIE QUESTION about dark passages in a DVD rip
By pbecks in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2007, 07:50
