i had a tough time ripping goodfellas to anything... i believe cause the disc is scratched... finally got dvd decrypter to rip both sides to my harddrive and they seem to work fine cause i can view them all in powerdvd... but, now that i have these video_ts folders i can't seem to burn them... i tried dvdshrink but when i choose open files i get "dvd shrink encountered an error and cannot continue. The error is: failed to open file The reason is: system cannot find the specified file."
any idea what this could be?
Results 1 to 9 of 9
With DVDDEcrypter did you rip in FILE Mode and in Settings did you select all files?
oh, i used ifo mode... would that cause the problem? I still have a folder with the .ifo and .vob files in it? sorry, i'm a newbie at dvd-ripping... so if i rip in file mode my problems should be solved?
thanx for the assistance. -
"so if i rip in file mode my problems should be solved?"
If you do it exactly as described in the guide above, it should.
"thanx for the assistance."
You're welcome.
Indeed, but not quite as well as v3 beta 5Originally Posted by handyguy
ok, when i get home from work i will try it... but, i guess this comes back to my original problem... the reason i was ripping with dvd decrypter was cause the movie is goodfellas and its pretty scratched up... i first tried to backitup with clonedvd and anydvd... side a worked no probs, but strangely side b gave me the old clone dvd 'can't copy css protected discs'.... i assume this is an error cause its scratched? ????
so, i tried dvd decrypter and at first it wouldn't work, but then i selected those error check boxes and i finally got it and it can play from powerdvd...
so, i guess i will try dvd decrypter again and maybe dvdshrink directly...
any idea why the b side reported that it was copy protected? i use anydvd 1.6.13 i think... could scratches cause this? -
you dont necessarily need a video_ts folder at this
point, ok lets just say all the files are in a folder,
let shrink open the video_ts.ifo and all is ok, if you
want only the movie, open the files say "vts_01_0.ifo,
all ur probelms are answered now, just be sure, the
new files go into a VIDEO_TS folder to be burned ok?
I have already ripped a BD to my HDD and now what to do?
By fjmr in forum Authoring (Blu-ray)Replies: 10Last Post: 19th Jul 2009, 22:16 -
Forced Subtitles in M2TS - Blu-ray Ripped to HDD
By saber001 in forum Blu-ray RippingReplies: 4Last Post: 23rd Mar 2009, 07:14 -
Adding .idx and .sub to .mkv ripped by dvdshrink and handbrake
By theredlaugh in forum DVD RippingReplies: 5Last Post: 17th Dec 2008, 12:11 -
How do I view ripped DVD from HDD
By Feelininvincible in forum DVD RippingReplies: 2Last Post: 27th Nov 2008, 11:07 -
A little help can't seem to burn this movie after ripped to HDD
By f-zer0 in forum Authoring (DVD)Replies: 4Last Post: 10th Apr 2008, 22:13
