I have been ripping using smart ripper for awhile but for some reason some of my recent rips the sound quailty has been poor( I actually listened to the vob files to make sure it was the files themselves), does anyone have any suggestions???
SmartRipper shouldn't have any affect on the sound quality of your .vob files. Don't want to jumo to conclusions, but it could just be dirty DVD's or even a dirty laser in your DVD drive. You might think of giving the laser a cleaning. If you smoke it can get a film built up pretty fast which can cause serious read problems in some cases.
I do know there are cleaning CD's available. I just do it whenever I open my case & open up the drive, use a Q-tip & Alchohol. I guess it depends on if you're willing to open up your drive or not as to which method you want to use.
Also check the DVD's themeselves before you rip them. Fingerprints & dust & smears all have an affect on the error correction. If your drive has poor error correction this COULD be your problem.
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
