  1. Hey guys, here's my situation. I encoded the video using TPMGenc Plus. Then inserted into DVDit PE, I planned on doing all my authoring in this then saving and burnign with DVD burning rom 6. But after i finshed maknig all my menus and such I tried to save DVD folder and I got "The resultion of this file isn't supported by DVD" and then it wont; go any further. Did i do something wrong in encoding or do i have to do somethign in the program, any help would be appreciated! thanks
  2. What resolution did you encode at in Tmpgenc plus. Did you select the right format (PAL/NTSC) when you started DVDit?
  3. Ahh, you know i may have overlooked that! I will check it out, probaly the answer too. Thanks
