I'm trying to write a .cue image with burnatonce. It fails and I get this log/error message:
ASPILOCK:2,1,0: LITE-ON LTR-12101B Rev: LKUA
Starting write at speed 12...
Turning BURN-Proof on
Using 96 byte raw P-W sub-channel data mode.
Executing power calibration...
Power calibration successful.
Writing lead-in and gap...
Writing track 01 (mode MODE2_RAW/AUDIO )...
Writing track 02 (mode MODE2_RAW/AUDIO )...
?: I/O error. : scsi sendcmd: retryable error
CDB: 2A 00 00 00 66 3F 00 00 1A 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 04 00 00 00 00 0A 00 00 00 00 09 01
Sense Key: 0x4 Hardware Error, Segment 0
Sense Code: 0x09 Qual 0x01 (tracking servo failure) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 10.599s timeout 20s
ERROR: Write data failed.
ERROR: Writing failed - buffer under run?
ERROR: Writing failed.
Does anyone know what to do? Actually I get the "Buffer under run" error message in VCDEasy as well. I came close to completing a burn with Alcohol (burned 600mb of about 800) before the writing failed.
I'm so close that I can taste it....![]()
Might need to update your aspi drivers.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Thanks. Ran the aspichk.exe program found on this site:Originally Posted by Ejoc
http://www.ncf.carleton.ca/~aa571/aspi.htm
Got errotmessage stating that ASPI was not properly installed.
Could I use the following link to maybe correct it?
http://download.adaptec.com/software_pc/aspi/aspi_v472.exe
I think I have heard something about another version (v.4.61?) being better?
Thanks for your help so far mate... -
I have now tried both the 4. 60 and the 4.72 version of ASPI. I'm still having the same problems (with all my burners I might add). Could any background programs interfer with the burning? The amount burned varies from time to time (from about 100mb to 600mb) until i crashes/freezes. It just gives up...Originally Posted by Ejoc
I have even tried to play the 600 mb one (cut about 200mb short though), and it works fine on my Phillips 731. Can't understand why it burns fine, and then just stops writing after a while...
VBScript to read XML. Assistance Needed
By NYPlayer in forum ProgrammingReplies: 11Last Post: 9th Oct 2012, 19:29 -
WMV to FLV assistance needed
By OM2 in forum Newbie / General discussionsReplies: 0Last Post: 10th Jan 2010, 07:45 -
region code assistance needed with the sony ns-700h dvd player
By stressed_with_sony in forum DVD RippingReplies: 1Last Post: 2nd Jun 2009, 01:53 -
region code assistance needed for the sony dvp ns700h
By stressed_with_sony in forum DVD RippingReplies: 0Last Post: 1st Jun 2009, 21:34 -
Assistance needed converting to WMV for playback on Xbox 360
By eggedd2k in forum Video ConversionReplies: 2Last Post: 16th May 2007, 18:29
