Is there anyway to convert a powerpoint presentation to DVD??
My Boss wants me to put one of our presentations on a DVD to run at a trade show.
How can I do this?
Results 1 to 9 of 9
Try this guide, never used it but ran across it for a friend who was doing something similar for one of his classes.
Sorry if this link is not allowed.
http://www.powerpointbackgrounds.com/powerpoint-to-dvd.htm -
Camatasia is a good piece of software to capture what you are doing on the desktop to an avi file. Also, you could use a computer that has TV out and run it to another computer with a capture card.
The rest would be like making any other DVD from a movie capture."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Has anyone tried this software?
http://www.dvdxcopy.com/products_dxp.asp?a=45907"When the gate drops the B/S stops" -
suggestion:
- open the presentation in powerpoint
- save as and select jpeg (.jpg) - each slide saves as it's own jpeg file
- use your favorite editing s/w and import each jpeg just like you were creating a slide show of pictures (memoriestotv or vegas or studio, etc.)
- take it from there just like you do now to create the dvd -
Just view this: http://www.powerpoint-to-dvd.com
PowerPoint2DVD is easy-to-use yet pratical
WARNING SPAMMER - DON'T BUY THIS PRODUCT
/ Moderator Offline tool to convert power point to DVD with your background imges or sound, and many powerful selection menu. It is really great!
Anytime you can search "powerpoint to dvd" at Google or Yahoo, you will also see that page easily!
How to add a DVD video to a Powerpoint Presentation
By andy jackson in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2012, 13:27 -
how can i convert a powerpoint presentation and put it on dvd
By shashgo in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2009, 04:14 -
Question about cutting clips for a Powerpoint presentation
By tanealbhandari in forum Newbie / General discussionsReplies: 16Last Post: 10th Dec 2008, 11:38 -
Powerpoint Presentation to Video/DVD Software
By Nasho23 in forum Newbie / General discussionsReplies: 2Last Post: 11th Apr 2008, 00:59 -
Which video format works best in a PowerPoint Presentation?
By foochuck in forum Video ConversionReplies: 1Last Post: 4th Oct 2007, 10:54
