I just got a Likko KC-2100 VDR off eBay, but I can't get it to record! When I put in a disc and try to record, I get the following message:
VencMpeg did not start
I can sucessfully record the audio from any source if I select CD-DA, but I get the above message if I select VCD or SVCD. I've checked and double-checked my connections, and everything seems to be correct.
Can anyone offer me any assistance with this problem?
I would try some different media and an RW, but it may be broken. Try using timer to start recording.
I've tried two brands of CD-RW and a few brands of CD-R with no luck. This model has no timer recording.Originally Posted by Nelson37
bummer it doesn't work. can the seller do anything for you?
I have had good luck with my Terapin VCD recorder
deadrats' review of the i3 2100
By deadrats in forum ComputerReplies: 11Last Post: 26th Oct 2011, 21:16 -
problems with dvd recorder
By john sheehan in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Aug 2011, 14:43 -
Total Recorder Professional Edition Problems
By Teac23 in forum AudioReplies: 0Last Post: 14th Jan 2009, 10:56 -
Problems with LG HDD/DVD Recorder 780
By cbgman in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2008, 15:27 -
Xoro HSD 2100
By TCEkryten in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd May 2007, 08:56
