Hi. I have an SVCD Video on my computer, and would like to know how I check what it's attributes are like bitrate, resolution, etc. Also, what's a good way to lower mpeg artifacts and increase clarity to your SVCD file? Does having a bitrate of 2520 (+ 224 if you want to include the audio), what it's set to by default in TMPGEnc) cause artifacts because on some standalone players it's too high?
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Entering Video Bitrate Makes Preset Switch To SVCD
By akulier in forum ffmpegX general discussionReplies: 7Last Post: 26th Feb 2008, 05:12 -
By akulier in forum ffmpegX general discussionReplies: 1Last Post: 21st Feb 2008, 04:31
