  1. when i selec this option the result is a m2v a mp2 and one mpeg , but i never use this mpeg,(only i need the elementary streams) is there a way for dont make this last mpeg, saving time and space in the hardisk?
    thanks
    inspector77
  2. This is a good idea for a new option. Will add to my to-do list.
  3. oh fine thanks!!!
  4. Out of curiousity, why would you need the elementary streams, unless you want just the audio--which I thought was an option/checkbox somewhere in the program?
    Tony
  5. To author them in DVD Studio Pro, or other similar programs.
  6. Anonymous
    Guest
    I found DVD Studio Pro 2 is very picky about the video files to import.
    Most of the .m2v and .mpv files that ffmpeg produces are not compatible with DSP2. I found the only format that DSP2 can digest is the high-res DVD preset with exactly 720x576 (PAL) size and "mplayer" as decoder.
    The "QuickTime decoder" setting will crash the application and make a coding within ffmpeg impossible.
    Otherwise a nice product which needs still a lot of work.
    Eagerly awaiting version 0.0.8e!
    Huggo
  7. I'm probably jumping directly to 0.0.9 very soon.
