hello,
i bought a few dvd's from region 2 when i had my region free dvd player (it since broke). now that i got a burner i would like to back them up and beable to play them on region 1 player. does anyone know how i can do this or which guide i should be following?
i tried it once with dvd shrink so i can get the menu's etc on the disc, and just before it starts, it asks which region setting you want. i put region free but it doesn't play in my jvd dvd player as it see's it as a pal disc and says it. when i start it up on my pc, it still reads as a pal region 2 discs and asks to change the setting.
any help would be appreciated.
thanks
I havnt had any region problems doing it like this
Rip using DVD Decrypter
Shrink using DVD Shrink
Burn using your Burning software -
What about your TV set ? Does it except both NTSC and PAL input ?
Sometimes the burner might be outputting PAL to a NTSC TV, which won't work.
I have a cyberhome DVD player and it plays both PAL and NTSC. But it is normally set for me to output to NTSC, because that is what my TV is. Fortunately, on the Cyberhome, there is a button I can press which converts the output like I have a total PAL player and outputs in PAL format for a PAL TV.
Can you get the file in a MPG or AVI format, then use something like Main Concept which will convert MPGs in DVD format from PAL to NTSC. -
my tv is for ntsc. i ran it through dvd2svcd useing their dvd setting. i'll just have to miss out on the dvd menu's and create my own, something i've not done before but figure its time i learn. i may try one time ripping through dvd decrypter and then going throuhg dvd shrink.
thanks for the responses.
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 18:30 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
