Compare to all the capture cards from vcr to pc. Which one is better and the best price (cheap)?
I've been quite happy with my Hauppauge! WinTV TV tuner card for capturing. Paid $20 for it on eBay. The only problem I've had is that the capture software that came with it captures in old-style AVI format which has a 2GB file size limit, and the other capture software I've tried with it drops frames like crazy while the software that came with the card never drops any frames. My workaround is to capture in approximately 8 minute segments with the software that came with the card, then use AVISynth to stitch the segments together for frameserving to my favorite encoder, TMPGEnc.
CogoSWSDS -
Theres a capture card comparison on this site.
Use it, its great.
What price range are you looking at?
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
you name it. I guess I'll take 100 bucks or below. I need neither TV to PC or VCR to PC capture card.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
