I'm using memoriesontv to generate a slideshow DVD type m2v files. I don't have a DVD burner and my DVD doesn't play SVCD. Therefore, I'm using the VCD header trick with the m2v file. The image is much better than the SVCD or the VCD (of course).
But, it has stutterer sound and the video is playing very slow. I believe that is due to the bitrate. How can I change the bitrate of this m2v file ? There is no option to do it on memoriesontv.
My DVD player is a LG3351n
Maybe I'm too numb for it.
But I can't change anything during the generation phase since its done by the memoriesontv.
My only chance is to change it afterwards. But as I said the file cannot be opened by TMPGEnc
NO SOUND after encoding!
By bondgirl1980 in forum ffmpegX general discussionReplies: 6Last Post: 3rd Mar 2012, 13:51 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 17:59 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
