Just wondering if anyone here uses those utilities to free up ram when they are encoding. I've only got 512 MB of ram and TMPEG chews it up like crazy when I'm making my VCDs. Are there any good utilities to use and what should I set the limits to? Thanks.
perdomot, as your operating system install gets older, you'll find that many applications install background services that run all the time. These are usually harmless, and more often then not, pointless for day to day work. You should clean these out, uninstall, or disable them. The method depends on which operating system you use. If your using any of the newer NT based systems, you can press Control + Alt + Delete, and select the 'Task Manager' button. Select the 'Processes' tab, and from there you can view exactly how much memory each process uses. The 'Performance' tab will show you exactly how much physical ram is in use, as well as CPU Utilization.
Impossible to see the future is. The Dark Side clouds everything... -
tmpgenc itself doesnt use that much memory, between 13meg and 26meg. I run quite happily with 265mb. sure its not your environemt variables -- temp cache -- that needs setting (somewhere between 1 & 4gb of disk space?)
I'm not exactly sure what to tell you guys. All I do know is that when TMPEG finishes encoding, the system is moving super slow. If I push Start, it takes several seconds for the menu to pop up and normally, its instantaneous. I tried one program a while back that let you see the amount of memory you had in the system tray and as the encoding process progressed, the amount of free memory decreased.
It sounds like a memory leak. What operating system are you using?
is your hard drive fragmented? video files are quite large and quickly fragment a hard drive
When testing the performance and reliability of an encoder, don't forget to take into account the Video codec used for the source AVI file.
The old, divx v.3 and 4 codecs are a mess. They are slow and consume memory a lot. DivX 5 is fine.
Also, another problem is with the OS itself.
Your description about sluggish OS performance after encoding a file, reminds me of the bad-old Win98 days. Even copying large amounts of data caused the same thing.
There is a single reason for this. Windows 98 - I guess this is what you are using - tends to use all memory as disk cache. Reading lot's of disk data, tends to overuse the RAM into a cache that won't empty unless some RAM management tool forces it to be released.
A trick to avoid this, as I recall, is to open System.ini (I think. It might be Win.ini) and find a paragraph named Cache or Virtual memory or something - it's been too long.
There, add the following two lines:
MinFileCache = 8192
MaxFileCache = 65536
Or whatever sizes in Kb you want. This will make Windows use no more than that for Cache. In most cases, this fixes the problem under Windows 98.
Of course, the perfect remedy is to remove this OS and use Win2K or XP.The more I learn, the more I come to realize how little it is I know.
h264 encoding does not use all system resources
By sharkbite in forum Video ConversionReplies: 3Last Post: 28th Feb 2012, 19:16 -
memory usage of CUDA encoding
By sharkbite in forum Video ConversionReplies: 0Last Post: 25th May 2010, 22:36 -
Will not render in Vegas says system is low on memory
By kILLDR3n in forum EditingReplies: 7Last Post: 26th Mar 2010, 12:44 -
Looking to Build a Dedicated Encoding System
By Scarpad in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2009, 13:10 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16
