  1. I was hoping this had been corrected in this new version!
    I have been using vdub to add black borders to top and bottom, is there an easy way to calculate the size of these?
    What size borders would i need to add for a 576x320 @23.976fps played on a pal tv?
    I also tried to use avisynth scripts, but couldnt get it to work correctly, so if anybody could advise me.
    Use fitcd to calculate. It can also direclty make avisynth scripts.
  3. The beta versions of 1.4 seemed to have some problems with aviSynth scripts. I haven't had any issues with the release version. Either way a VAFPI wrapper should take care of it. BJ_M said he sees intermittent issues with aviSynth, for me it's been all or nothing.
    As Baldrick noted, MainConcept likes to impose it's will on you for framesize vs. aspect. The only way I've found to get it right is with aviSynth.
